Not me, I'm out for turbo doll hairs $. If someone buys my GS for the right price will jump into an STI for something different.
Harrop chargers are so nice though :) same deal with their brakes etc. big doll hairs but good performance
Edited by UNR33L
When you consider how much 88E has ramped up (50%) in just a couple of weeks based off fairly expected news announcements, you have to believe that with a joint venture or buy up deal on the table this thing would go from cents to dollars in a matter of days
Had my Dell laptop for over a week now. Had so many issues with it out of the box.
- Selecting Standby in the start menu would shutdown the laptop (fixed)
- Selecting Shutdown would put in standby (fixed)
- Laptop hangs at the Starting Windows page only when restarting (im still trying to fix this...)
- Laptop takes same time to boot as my old laptop, which was a f**king lean machine once I'd tampered with it, but pretty poor form.
- Has AMD gfx card, but doesnt use it for anything (fixed, had to install AMD drivers and software then specifically assign programs to the secondary gfx card)
- comes with two sets of audio and two sets of wireless software/drivers, but uninstalling the unused ones disables the device completely. dont make no sense.
- a whole bunch of other shit that I've fixed but have forgotten.
I'm contemplating a clean install, but worry will cause more issues than fix. Especially since it doesnt have a DVD drive built in and Dell supplied all the backup drivers and OS on DVDs. yay.
1 hour ago, UNR33L said:
Clean install win 10 brah.
All of that is just software related issues / bloatware
ive removed a lot of the bloatware.
Also, has to be win7. I need to put the Zoltan unit on win7 too, it runs like a pig with win10.
4 hours ago, dezz said:
Dell sounds like a great choice..........
it never was a good choice. But its what the boss wanted, and he's paying for it.
Edit: oh yeah, tried to use the laptop on a TV last weekend, f**king no audio through HDMI. HDMI/TV not listed as a device. Has something to do with the Intel inbuilt graphics drivers.
And also that stupid Dell Audio software. Turn off artifical sound enhancements, then when you close the window it turns them back on again. And theres no fix for it. It uses Realtek drivers, but if you uninstall Dell Audio then the sound stops working. FFS.
yeah used to be easier, was basicly a mobo perm attached to a screen.
but you could swap HDD/cpu/ram/Graphics.
now it's pretty well all onboard so what you see is it.
but makes them significantly thinner and lighter but less fixable.
Shame you can't just build laptops like you can PCs...or can you?
this is why I wanted a metabox. Standardised chassis, pick your components and they set it all up for you. Then you know exactly what you're getting and can save money by removing shit you're never going to use... Like Bluetooth.
This is the way Dell used to operate, to a degree
I picked every component in my Inspiron 12 years ago...sound card, gpu, cpu, screen type, hdd size and speed, ram speed and size, bluetooth, wifi (when it was an option), minimal bloatware. Back in those days they gave you a myriad of options to choose from and it wasn't vastly more than the cost of building things yourself. I remember the equivalent spec laptop from HP/Lenovo/Acer was 3k+ and my Dell came in just over 2k.
Not likely, but you can always disable your bluetooth controller anyway.
If you like our company can set up your laptop for $200ex / hour.
Also nice gif, good movie.
Edited by UNR33L
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
