9 hours ago, Birds said:
On the open wheeler note
https://www.carsales.com.au/private/details/Ariel-Atom-2004/SSE-AD-3899997
Why on earth would you need that much power...sounds awfully close to F1 kw/kg territory
no mention on the fact the chassis was cut up and rewelded to new dimensions to pass au kit car rules.
or the fact I don;t think it has finished a track day without blowing something up.
have seen in the pits a few times years back and closer it gets the scarier it gets...
Dezz when you are installing windows 10 make sure you delete all your existing partitions on your hard drive, then create a new partition for the full size (it'll be empty) then install on that.
(Probably self explanatory & do it anyway just checking you're doing it right and not installing over the top or 'upgradeing')
It's a lot of money for an experience... And that's about it.
Again, would go for a Caterham. At least they are proper registerable and the duratec/zetec motors are known quantities with info and spares.
Probably wouldn't have done what you just said actually... Left it downloading over night and didn't check it before work this morning.. Can I still do the partition now or do I need to start again? Laptop was wiped and windows 8 reinstalled, I've only put shit like utorrent and ipvanish on it so far..
Would give a 620r a solid go.
It will wipe what ever is on the hard drive currently, so you boot from windows 10 usb stick > install windows > custom / advanced > you'll see your hard disk and it's partitions, delete them all so it's empty, unformatted, then click new > accept the default size (it'll be max hdd size > click on your new partition > install > wait 30 mins > done
You now have fresh windows 10 install with no other crap left over from windows 8 etc. Laptop will be faster, better stronger.
There'll be a youtube video somewhere of it surely, but my instructions should be good enough
Edited by UNR33L
f**k lots of steps involved.. Think I just upgraded when I first went to 10.. But laptop is pretty much empty at the moment so I guess I'll do it... I think the os is automatically installed on the SSD and the sata drive is just for everything else and porn...
I'll read your instructions when I'm at home and not balancing on the edge of a switchboard.
It's pretty easy, and it's worth while doing a 'fresh' install over just an upgrade.
Yeah install OS on the SSD ofcourse, you can add/format the Sata drive in later for your porn in windows disk manager
Edited by UNR33L
If I do this partition shit will I still be able to install 10? Was under the impression it scanned your computer for a legit windows licence before letting you update to 10.. If I've formatted completely, won't I lose that?
Nah it still works, key is embedded in the hardware
13 hours ago, blah_blah said:
Can confirm Gregs car is an absolute beast. id be surprised if any rwd skyline on here could beat it from.a dig. Birds pls respond
You just can't climb in the ring with Ali cause you think you box
  • Like 1
    • Coming home late at night and driving past the police is the only reason i need one haha And yeh, definitley needs a switch to quickly enable it, dont have time to be getting my phone, opening an app, waiting for it to update etc before being able to make the change
    • Because it is financially convenient for them lol. Why wouldn't they want to give you the lowest possible valuation for your car?
    • Yep. @Duncan also shannons they will rip you dry and will be probably limited on how much you can drive. Also keep in mind that you always have to have it garaged with Shannons, with enthusiasts as per their PDS you can have it 2 times per week on the driveway for example.
    • I had a generic 4" Varex rear box on my old V8, worked a treat for sneaking home late at night, it was as quite as stock when closed The car was "fairly" loud when open as it consisted of 1" 7/8 headers to 3" catted Y pipe, to 4" single, it did have a resonator in the mid pipe and only the Varex out the back I also hard wired in a Varex dash mount switch, as the key fob thing is a pain to use when driving I wouldn't recommend giving the beans when it is closed though as it creates a large restriction in the exhaust  It also can in very handy when pulled over for "random" breath tests or just cruising past the constabulary
    • Here is the before and after of the scraping/sanding of the IC pads on the tachometer board for the fix mentioned in this thread. And yes it worked fine after. Just a note if you change any components on the board the tach calibration can be wrong showing the wrong idle etc...only problem is once it is installed back in the cluster you can't get to it to adjust...ouch! My fix was to cut out the calibration pot (the blue one) from the board and run it with two wires to the fuse panel under the dash where I could adjust the idle calibration once everything was installed. And yes I soldered everything up again including the half soldered components either side of the IC in my photos
