52 minutes ago, UNR33L said:
Have any of you fellas actually put a time down the 1/4?
Greg/Birds/Toby?
I know Hame did like a 12.6 or something which is still one of the better times I've seen for a street skyline with coilovers and hellaflush fitment
I'm a god damn street racer
The only slips that matter to me are pink
BorgWarnerlinesaustralia
Toby, before jumping too fast onto the EFR bandwagon, you really look into how much effort it will be to bolt one on to your setup? Do you need a new exhaust manifold/hotside piping/wiring for turbo speed sensors/new oil & water fittings/boost controller.
Greg/Birds/Toby?
Never really interested me to go to the drags to be honest
I think greg went recently? Not sure what his times were
Greg/Birds/Toby?
I did 12.6 with dying AFM's, rubbish BC coilovers and tune that makes more black smoke than diesel Golf.
Digging the MX5 RF
http://www.caradvice.com.au/515564/2017-mazda-mx-5-rf-review-2/
Not sure how someone over 6' would get along with it though
I'm sure it's fun to drive like the 86 in the bends, but if Mazda would just give these cars a small turbo and/or some respectable power, they would play havoc with the 86 and hot hatch markets. It's certainly cheap enough to be a serious contender.
16 minutes ago, HEKT1K said:
Mrs needs a new car
dare I ask wasteland for suggestions?
we're obviously considering an r33, an fpv gs, and an sss pulsar at this point
What about...ah nevermind
17 minutes ago, HEKT1K said:
Mrs needs a new car
Budget? Econobox or premium?
2nd hand mazda3
cheap, now and hold value, reliable and the sportier ones can be ok to drive
so so easy to drive in city as well
4 year old and sub 40K km
http://www.carpoint.com.au/all-cars/dealer/details.aspx?R=OAG-AD-14654399&Cr=1
  • Like 1
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
