Car question:
Whats an equivalent spark plug for BCPR7ES or something that is a decent copper plug that can suit up to 400rwkw (including 400kw).
And can I buy them off a shelf.
If so, where. All info seems to have disappeared about 2012 re: Spark plugs and none of this stuff is on shelves anymore and I want to buy them on the weekend, in Melbourne.
Car question:
Bkr7e but try R and E auto parts on centre rd springvale. Next door to repco. They usually have stock of bcpr7es. If you get stuck I have a set of 6 that I've only used for 50km. Replaced them chasing a misfire that turned out to be something else.
  • Like 1
I have some iridium 8's that were $75 a plug and were scheduled to last a lifetime. They haven't given me an issue but I do get misfires at 20psi (380+kw).
So I thought to stop using amazing super plugs, and wanted a basic plug that is known to work, as its cheaper to try that first than replace Splitfires (which are now getting on in age, almost 10 years).
I got a misfire at idle that went away, and I'd like to have plugs in my hand ready to go should they be needed instead of looking ages later when I have a car running on 2cyl or some shit.
Car question:
I was using bcpr7es plugs at 394rwkw.
So I would just get those.
Guess I'm headed to RE Autoparts then!
They seem harder to find than most, these plugs, figured people would have found some other alternative on a shelf. Good to know the BKR7E is usable if in a pinch
I get my BKR8's from Springvale Autobarn. or Bursons. i cant rememeber. I got a box of em.
24 minutes ago, admS15 said:
Everyone stocks 6 heat range but not many have 7. Greg also give bursons a call if r and e has no stock. So are you planning a track day this weekend ?
Nope, just had misfires at 20psi and a random one at idle today so wanted to have something on standby.
$80 plugs you use "forever" I don't trust to actually last forever :P
Nothing lasts forever, especially plugs. I got sucked into iridium's once, never again on a modified car. Copper for life. Like birds, I buy them in bulk. Last couple of times through spares box, where about $4 each and free delivery on overs over $50.
How the f**k did you research plugs on SAU and then buy iridiums expecting them to last?
There has to be at least a hundred threads telling you not to bother and just use BCPR7ES
Iridiums aren't a total scam per se, they do last for many times longer than normal plugs do...but the assumption made by the marketing claim is that they aren't going into a high performance car. A daily driver can use iridiums and will probably not notice a degradation after 50,000km etc. because performance decreases aren't as obvious nor are the plugs performing in an extreme environment. Iridiums wear like copper plugs do, but will retain say 70-80% of their performance after 10,000km, unlike the latter. This is useless in a high performance environment where you want plugs to be delivering 95%+ and as Iridiums can't do that any better than copper, better off saving your money.
I didn't research here. I spoke to Trent @ Chequered while my car was literally being tuned, and asked him what plugs to recommend for my setup at the time, taking in account my timing, ease of change, desire to not have it blow out and for it to last forever.
What he recommended did just that, I never had spark issues until I took a lot of timing away, and took a lot of boost away.
So I was asking on a more common setup, which is closer to what I have now, and the BCPR7ES work really quite fine, no misfires at all and I'm really happy with that, and really not that hard to change or check. The old plugs really were going strong but not suited to what I am doing now (they were also too cold a range, looking at them out of the car)
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
