47 minutes ago, joeyjoejoejuniorshabadoo said:
Been driving to the new.job for a few months now. Gotta admit it would be f**king hard to go back to the filthy train
Ignorance is bliss
I'm still on the free early morning train..... train
  • Like 1
6 hours ago, UNR33L said:
Arguments on both sides, some would say no point having a cheap daily if that's what you spend most time in, obviously if you could have a baller daily and baller weekender that's different, I'm going down that path with motorbikes though, track bike and road bike, at least they're cheaper $.
I thought 9.5? Check out some of the Vertini, HRE, Niche etc , thewheeldeal website has some good options, I think eastcoast tyres also recently opened a shop in Bayswater (they are big in sydney for holden and ford ranger boys)
Nah...cheap daily pros:
- Appreciate nice weekender more
- Less f**ks given if it's stolen or smashed
- Less depreciation from high mileage
- Generally better fuel economy
- No compromise made on the weekender which can have two doors and no tow bar
- Auto daily, manual weekender
All rounders compromise somewhere...in comfort or fun factor
All in one. Daily and track hack. No f**ks given for fuel economy or if it gets smashed or stolen. Comfortable enough as long as there's no speed humps and fast enough at the track to leave some dedicated track cars with a wtf look. If I needed to, I'd consider a tow bar. R33 GTST, perfect weapon for that type of thing. Definitely a compromise but still works damn good.
This is what I'm doing now and it is one of the better cars to pick as an all rounder, but if I had the space I'd have an econobox auto daily for sure. Probably a Hyundai as their recent models are damn good value for money.
When I had a 34 GT-T auto with stock suspension, it made me appreciate the 33 manual more on weekends and vice versa.
The 33 won't work for everyone but in my current circumstance, it's perfect. I have an m35 stagea which is as comfy as driving a sofa as a back up car/workhorse but would rather daily the 33. Why have a fast car and drive a slow car everyday. It's just not something I can do. I've never driven anything slower than a 14 sec car and I'm not about to start now. Yes, there are newer tech cars out there that can do the job but then you've got to factor in depreciation, costs to make them faster and most of them don't make you feel like your really driving.
If I was you birds, I'd keep dailying the GTST and track it if you feel the need and have gtr as weekend duties mobile.
What happened to F-Zero winning rims Billiam?
I barely drive on the weekends as it is, and if I do it's to the track anyway(towbar) or to coles, fuel economy negated by having to pay rego, insurance, maintenance on a 2nd car.
I wouldn't want to spend 6-10 hours during the week driving a shittier daily to only have much less time in a nice weekender.
Auto daily and manual weekender would be nice though.
Edited by UNR33L
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
