$160 car hire.
$360 one-way airport drop off interstate
28c/km after 200kms.
Ill worry about reimbursement later, just glad to be home. Gave someone from site in a similar situation a lift so was good to have someone to talk to.
What did I get from it over other options? Bus/train didn't leave till this evening, arrive in Melb at 7am. Business class Qantas was $1200 and didn't leave till 9:30pm. First economy flight out of Sydney was 6am next day. So I basically got home the quickest method possible.
Well played [emoji106]
  • Like 1
Came in with ADR37/00
so 1/2/86 so all cars after that date, plus any older car that has a motor from that date onwards.
so fit a Miami V8 to a XD falcon and legally need cats.
The ADRs do not mandate the use of particular technology, although it has been necessary for vehicle manufacturers to fit catalytic converters to light petrol and LPG vehicles in order to meet the emission limits introduced by ADR37/00 in the mid 1980's.
https://infrastructure.gov.au/roads/environment/emission/index.aspx
Implementation date for that ADR:
https://infrastructure.gov.au/roads/environment/files/Emission_Standards_for_Petrol_Cars.pdf
  • Like 1
Legend.
I've made a list of things to do with the Triumph, it's not surprising and not hard, just takes time. Still predicting $1000 plus tyres to get it where I'm happy to sell it. Really depends on how much additional is needed for RWC. Need to find someone who isn't interested in making money off stupid shit, maybe I do the ol' leave something obviously deliberately to keep them happy?
No idea. They start at $5k on Gumtree in average condition. $9k on carsales for a neat version. I was gonna aim for the $4-5k region, just to get interest and move it. No point aiming high and playing the waiting game.
I don't mind cleaning up and let the car sell itself. Though not sure what to do if multiple parties interested.
Ummm not sure what it's worth to me now.
So far owes me $70 tow, and $150 car cover because I didn't think my sisters mazda 2 hatch cover would fit it but is actually perfect...
2 tyres have gone borderline flat and it's shocking to push because I think one of the front disc brakes has "locked".
If you're interested Martin, you need to come see the car. I'm open to offers. I haven't bought any new parts for it yet, but was going to start in the next 2 weeks.
Even just to try and get the motor running and rolling.
(replace fuel, get friend to play around with the carbies, new oil/coolant/filters, sort brakes somehow). Car hasn't run in 10years so it's gotta be done.
Just seen too many people loose out when they try and fix up things on cars to sell,
My logic is you should only be spending money if you think you will get 1.5$ back or more for each $ spent.
that said a non running British car from late 70s/early 80is is prob not going to sell for much. (50$ and a ham sandwich anyone?)
I'ld prob more spend a little to get it running, fluids/filters/carb rebuild kit (all stuff you can do at home and not get charged labour for) and then try and sell it on.
the more you spend the less you will get in return.
and spending $600 on getting a carb rebuilt doesn't raise the value of the car by at least that much, since someone else could come along with a complete carb that works poorly for $200... but it'd still make the car run.
Just because they're listed for that doesn't mean they'll sell for that
/everyonewhoeverlived
I am no fool. My car is in better condition and will advertise for marginally less than them.
For the bare minimum, just do enough to get the engine running and prove the trans/diff is working. (Even if it's just the back end on stands as the brakes are locked) as they are the big $$ things that people want to know are ok.
40 minutes ago, emts said:
but if rebuild kit is 22$ plus delivery per carb and you can do it yourself..
http://www.rockauto.com/en/catalog/triumph,1979,tr7,2.0l+l4,1280012,fuel/air,carburetor+repair+kit,5964
100% this... it's the labour that kills you if you don't know any better. Especially on cheaper cars (<$10k) like this
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
