1 hour ago, Leroy Peterson said:
I should make my triumph project go public for sourcing funds. Anyone want a share?
Sorry mate I don't dabble in penny stocks
23 minutes ago, Birds said:
0-100 in 9.3 seconds
That's not gonna beat me in a drag
that limo? bullshit. i'd be surprised if it could do 100km/h
9.3sec must the stock Fairlane time.
so lets run some numbers on this...
the base weight on a 97 Failane was: 1642 KG
standard Engine was 162KW and 361Nm of torque
which we get a 9.8s  0-100
Great. now they replaced the 162kw with a 3.5l Mitsubishi motor, which we can gather was the magna one.
Magna 3.5 147kw and 300Nm
hmm not a good move..
now add in a second rear axle and suspension.. there has to be a good 250kg there for everything (axle, suspension, brakes, wheels)
add in an extra 6 front passenger seats (so it appears) circa 40 kg each for those so there 240kg
so we have ditched 10% power and 20% torque and we are 30% heavier  hmm getting worse.
now the big one that stretch, to keep that from bowing and adding 2 extra doors there is some serious metal involved here lets be generous and call it 800kg
so we are now at approx 3000kg
now a quick google says the GMV of a magna was 1884kg and had a tow weight of 1500kg so 3384kg
so would this do 100 and cruise yes.
but wait you idiot I hear you screaming..you forgot the passengers....
so call it 1 driver and 8 in the back
average au person weighs in at 78.5kg from ABS
so lets add in that extra 709.5kg in
so we at 3641.5kg... best case
using a online calculator:
http://www.060calculator.com/
gives us a theoretical best time of 14.8sec 0-100
assuming the engine/transmission does not explode as it is now past it's duty level..
yes I am bored today
SURELY it would be a pajero diesel engine? Traversely mounted FWD engine would sense. But fark that would be the worst driving car ever. I wonder if it's cable throttle the length of the car/bus...
it states 3.5L and pre 2000 (the build date) my only finds were the magna engine, (same engine was in the pajero but makes more sense to use the magna one as no transfer case and such to stress about.)
cannot think of any drive by wire cars from that era as well so yeah that would be all cable operated, the gear box mech would have to be weird as well unless you built an actuator on top and had it as push button
In the description it clearly states 12 + driver so there's a heap more seats and people you aren't accounting for.
  • Like 1
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
