4 minutes ago, TiTAN said:
In the description it clearly states 12 + driver so there's a heap more seats and people you aren't accounting for.
so it's counting a bench front seat.. yeah right who sits in the front of a limo
and the bech at the back as 3...i'm not crouding in that hard.
I went with 2 on the rear seat and 1 extra in each of the 6 new stand alone seats.
plus a driver in front.
could you get more, yes, would you tho..doubt it
Correction---
your right I didn't look at the pics close enough and yes there is a 2nd rear facing back seat. so lets add an extra 157kg to this...
It shouldn't sink anyway...what idiot sells out of a stock because of a one week delay to a procedure...do they even know what they are investing in?
People have sold off for dumber reasons. Also this week delay was unplanned, which is not great for morale/confidence.
Stupid people...if it said a delay due to something that is likely to ihibit success, I would accept it. A delay due to something that can easily be fixed within a week should hardly be a decider whether someone stays in a spec stock or not. The bet here is on the flow results, i.e. whether they can get profitable oil out of the ground, not how fast they can do it.
The only other reasons I can think of are short termers who hedged everything on getting an announcement this week, or people expecting a drop on any announcement and trying to beat others to the chase so they can buy in lower.
42 minutes ago, emts said:
needs more low,
but yeah looks like a fun car.
Why sell it, not going to make you any real money, and you could pop it on club reg and have a weekender.
yeah the look of it is growing on me. Since ive never driven one, i cant comment on what its like the drive.
Theres a bunch of reasons why I dont want it.
- Most people convert to electric ignition because old car. I probably would want to too
- drum rear brakes.
- rust is always a concern, even if car has none visible. (not sure how im going to check the fuel tank...)
- not fast enough for my liking. fast mods is more money, less reliability. apparently they're about 1000kgs, but the nameplate says 1300kgs ??? surely not that heavy...
- electrics are pretty damn nasty. ive become pretty fastidious and would want to re-wire the entire thing, which further takes it away from "original" spec.
- I dont have space and i dont want space for more cars.
- 2x project cars and rarely being home is hard enough as it is.
- I would prefer a sunbeam Alpine if I had to choose a british coupe
If I had a mortgage or something and got rid of the gloria, then yeah, i'd probably tinker with it and hold onto it. I dont think they will fetch big money like its older cousins in the near future, so dont see it as an investment. However, its relative simplicity and cheap parts plus that old car character make it tempting...
    • Driveability will be about the same with either externally venting BOV, or no BOV at all. Perhaps worse one way than the other, with me thinking that the definitely more flow going through the AFM through a venting BOV more likely to cause rich stalls than the perhaps more flow that the AFM might read on reversion. There is no such thing as "turbo damage" from not having a BOV at stock, or even quite a lot higher than stock, power levels. You need a big turbo with a lot of mass spinning hard getting a horrible slowdown from a slammed shut throttle before there is anything like the shaft loads required to damage things. Not an issue on small turbos. The ONLY 2 reasons that Nissan put a recirc valve onto the RB were: It is a bypass valve. It is open when under vacuum. When not on boost, it bypasses intake air forward around the compressor, which unloads the compressor, allowing the turbine to sping more freely, making the whole lot a bit more efficient when just puddling around. Throttle response should also be faster via the shorter, smaller diameter BOV pipe (when in NA, ie before the BOV closes and boost is building) which is nicer for driveability. Emissions. The reversion causes CO pulses. Eliminate the reversion (or at least, keep it away from the AFM) and you don't get that. The stalling/driveability aspect could have been tuned around, as shown one example of by dose above, if Nissan hadn't put a recirc valve on. Many many turbo engines before the RB had no BOV. They did not stall. See the RB30 turbo as an example. Nistune is definitely better than just stock ECU. It allows you to access and change things that are not excellent on the stock setup, and allows you to do mods like put decent injectors in, relocate the AFM, put a bigger turbo or even cams, etc, on, change to coil swith completely different swell needs, etc etc. All the things that you might need or want to do 25 years after the car was new. Aftermarket replacement ECU is obviously better again, because it gives you even more freedom from the constraints of the stock ECU. I won't be needing to go any further than Nistune though, for the new turbo in the 250ish rwkW region I'm going to, with big injectors, and most other things being stockish.
    • Lucky the prp block is supposed to be released next weekend
    • Wow guys thank you very much for the HUGE info :-) @GTSBoy I have like 30 minutes if test drive with that car/engine and it not stalled once. IMO it ran very smooth so i guess it was not that bad(but asi i said it is stock) That atmo BoV is worse than no BoV or in my case or it is/will be the same? Cuz frankly i rather have little whooosh sound than that sututu 😄 But either way the less harmfull for engine/turbo the better(if the stock is not an option right away) Yeah about that rebuild i talk with guy who will be doing swap and custom pipes...i think i can get stock BoV or get aftermarket which will function the same. Yeah i looked at that R35 option and i try ask my mechanic more about that if he knows. The engine has stock ECU but i can get Nistune for it. On that stock it runs quite well...but i have limited time with it so rly dont know. Ecumaster is this https://www.ecumaster.com/  It is not some dodgy backyard ECU :-)  @MBS206 Yeah but it will be better to have Nistune than the completely stock ECU no? About that "same" atmo/no BoV. The drivebility would be the same? I dont know but i kinda guess that amto BoV would cause more problems than no BoV in my case? Or is the same? You just "change" one sound for the other? Yeah i read many many many topic about hurting the turbo. But no one know anybody that would 100% tell that his turbo/engine blows/get damaged by not running BoV. Of course turbo would be little happier IMO if it has BoV ..but if you do not trash i think i should be good. And as you can see iam already trying to get this right...just working what i have right now :-) Yeah iam kinda the same...i dont want nothing loud and frankly iam not liking that sututu noise that much 😄 i rather have little bit of "whooosh" or no sound at all. Of course in my case it si a completely another world when you came tu Turbo car with open air box and no BoV and you driving the N/A ...all i hear is engine. Here? I heard turbo/sucking and that sututu 😄 @Yeetus So in my case it is really no difference to run no BoV or some atmo BoV like GReddy FV2? The car would drive the same and has "the same" little problems? As i wrote above i kinda thinked that atmo BoV with stock MAF would cause more problems...but then again i dont know much about no BoV either :-)  So to avoid stalling i "cant" just put neutral on stop lights like from higher rpm? Or? Yeah iam already looking for ECU :-)  Yes iam at the same side with thar R35 MAF :-)  @Dose Pipe Sutututu Thank you i (my mechanic/tuner) will look into that) Guess iam taking the Nistune at least :-)
    • Here's the workaround with Nistune I was talking about, just add in more timing on the decel table And play around with the fuel cut & recovery, it's enough to stop it from stalling on a decel
    • Hi Apex and welcome!
