i havent even reached my final form.
but i do feel an overwhelming and sobering reality.
ill never get younger, and life is going to become more and more serious. :(
why more serious? I found early 30's were the best party stage so far,
f**king lol.
The judge heading up the royal commission on union corruption has charged taxpayers $125k to come to the conclusion that he shouldn't have to retire from his $12,400 a day job, despite the fact he himself had previously said any judge that a reasonable person could possibly consider biased must rescind himself.
And his excuse? He doesn't know how to read email (but has 2 computers in his office)
Jesus...
Unless you're consistently producing cures for diseases and the betterment of mankind as a whole, no one is worth that a day and anyone who thinks they are should be shot.
sports people?
Kanye?
the pope?
Sports people make money for whoever is paying them... If nike pays LeBron James 100 mil then he's obviously making them much, much more than that.
Doctors/surgeons etc are more important to the world, but they don't sell a product or fill stadiums so they're not worth as much as sports stars in a monetary sense.
That's not to say it's right, but it's how the world works
sports people?
Kanye?
the pope?
My statement remains for all.
Sports people are ridiculously overpaid.
Arguably advertising and sponsorship has ruined a lot of modern sports at the elite level.
Lol
Fk politicians are stupid.
How do they all think they can just breach whatever rules they feel like? You would think when doing it they would expect it to come back on them like a ton of bricks later, but in reality they just sign the documents as they expect it will be covered up.
How often this stuff goes on geally goes to show the sheer arrogance of the job and how common it must be
Lol
Yeah it's a joke it's the old saying though who watches the watchers?
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
