Why is there Victoria Secrets in every Aus international airport?
I always wondered, then when Sydney was getting reamed by traffic control and every flight was delayed, people go to EVERY shop just for something to do. Then people buy stuff. I reckon those businesses only need maybe 4-5 disaster days a year to make their money
4 hours ago, TiTAN said:
That brings us neatly to a very important question, Why is there a Mercedes dealership at/just outside the Melbourne airport?
That's a excellent question.
I've no idea.
You may have just uncovered the reason why a form of transportation built around near perfect number crunching and mechanical reliability is less punctual than a bus.
Parking is $10 in Docklands and yep, free tram zone.
Am 16km in distance to city so unless I bring the Ebike into the office and charge it at my desk.... it's not possible?
They're pretty pricey those Ebikes! Might as well get a motorcycle, plus I've always wanted one and seems like an extra excuse to get one me thinks.
Quick question for everyone, how does a deaf person know when to stop wiping their rear end after a poop???
"Normal" people have five senses right?
When one lose a sense and the remaining senses are heightened (not sure if it's right word).
For example, me - I'm deaf as pole as y'all know, i go to the toilets and do my business and when it's time to wipe, I go by feeling between my butts with toilet paper of course.
Also you can judge by looks if you're flexible like pole dancers - that being said I'm sure they don't do that way.
Or you could heed Birds advice and do 15 wipe system.
Please try these and report back I'm sure we all would love to know.
On the subject of e-bikes.
Surely they're expensive as everyone first looked, although there's a couple of benefits - no licence and registration is needed until the government decides it is needed which won't happen I reckon as it's still a "bicycle"
On 10/14/2017 at 6:10 PM, joeyjoejoejuniorshabadoo said:
Literally the dumbest thing I have read in 2017
Welcome to my workplace on Fridays, I'll see what other knowledge I can share with you guys this Friday.
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
    • Sounds good. Provided the panel is flat/level I'd be happy to start the painting process.  While you are learning, for sure you could do this. Its only paint, you can always sand it all back and start again. Its only your time and money on materials, but while you're learning, really its time and money spent on your education.  Once you know how to do this bodywork and painting, you won't want to waste your time and money on frivolous activities lol.
    • Yep I will use a guide coat after putting filler, I will do it on the whole panel as I'm a beginner so chances I've made quite a few errors. In that photo, I think that was a low spot, I just for example said to pretend it's flat but I will put filler + guide coat after to assess where I'm at. Yep with that picture, the panel is wet as it rained when I took the photo. But all those scratches are completely smooth, I went over it with 240 grit and can't feel it, even with my nail digging into it. I was legit thinking to buy a 2k can and spray primer to see how it turns out but then thought to myself it's going to be a mess doing it haha. Good mention there. Thanks for all that info I think I know what to do next.
    • Prior to laying down the primer, you need to make sure the surface is completely level. For example, based on this picture, I strongly suspect that the areas marked in blue are higher then the area marked in green.  If you spray primer over this entire area, then paint and clear it, the finished result will 100% show the low area. It will stick out like dogs balls. Unfortunately the paint won't magically level out the low areas as you lay it down.  Without seeing it in person, I expect that the green area will need to be filled, then use a guide coat and check that the entire repair area is level with a large sanding block.  With this picture, are you saying that even though you can see the scratches, the panel is in fact completely smooth and flat? If this is the case sure you could prep and paint it as it is.     The picture with the paint you described as blistering, it's hard for me to comment on from the photo alone. It looks like the panel is wet? Dunno, looks strange. Does the panel feel as smooth as glass when you run your hand over it? **** Going back to your question again, generally you would only sand the primer if you made a mistake while laying down the primer.  If the panel is prepped properly and you lay the primer down properly, you should not need to sand the primer.  This wouldn't work - Don't prep the panel. Spray primer and see how it turns out. Sand the areas where the issues appear. Spray more primer and see how it turns out. Sand the areas....... Yeah you'd go round and round in circles getting no where.
