8 hours ago, Birds said:
$75 gets you five dozen at Krispy Kreme
You know what to do
I have one KK a year just to remind myself how bad they are.
if your going to go a Donut it has to be a freshly cooked cinnamon one.
lost about 13 kg this year, plateaued out from diet alone, need to move to phase 2.
it's a bunch of cardio and weight room.
so basiclly everything I need in short term. When I need more I'll end up buying it and putting it in the shed.
was at the pub last night and it was Parma night! (you join the gym at the pub)  but the rowing club owns the pub so yeah.
can join the club as a Pub member for 5$ to get the discounts, or 75 for Gym membership and 150 for rowing membership.
http://www.nagambierowingclub.com.au/about/
5 minutes ago, TiTAN said:
How can they possibly survive on $75 a year memberships?
They're counting on people to give up and attend the parma nights instead. Everyone knows that gyms make the majority of their profits from markups on alcohol sales.
Inb4 pub on sells beer and parmas
According to some people gym equipment is straight forward to use, others are so anal about technique...
If you want the pin loaded machines to work the muscles that they are intended to work you need to be using it correctly. The more weight you are using the more important technique becomes as you are more likely to hurt yourself by doing it wrong.
Clearly we are missing out on some profits by not having liquor licences at our gyms. [emoji848]
Seems pretty standard. On my watch list. CPH did the same thing when it listed, then went below initial price over the course of a month, could be similar here being so pricey for pharma.
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
