2 hours ago, dezz said:
I didn't even bother trying to work out what he was talking about...
was in reference to someone saying something along the lines of only 800k profit is a good investment
1 hour ago, dezz said:
I see
How's the doggo going? From your instagram posts looks like a cool pup.
Did you take him to puppy school / training?
Edited by UNR33L
you mean, bitcoin smashed though 10K, hits 11K nearly drops to 8K slowly starts to rally
fun 24 hours
http://www.smh.com.au/business/markets/bitcoins-wild-ride-continues-with-20-per-cent-plunge-in-90-minutes-20171129-gzvlfg.html
oh and people are going to get taxed on these shortly..so much for anonymous
http://fortune.com/2017/11/29/irs-coinbase/
Finally back home for good. Can get stuck into the cars.
  So apparently the instrument panel lights on the triumph are purposely fused with the tail-lights as a warning to the driver to check the tail lights... but its not usually the fuse thats the problem, its the contact to the fuse. Need to get my dremel out tonight and also purchase a bunch of new globes. Fingers crossed theyre not some weird shitty sizes.
Narrator: but as it turns out, they were some weird, shitty sizes.
Actually they're not. I could actually purchase the globes from Bunnings (if they sold 12V globes).
I'm sure BA15 bayonet sizes are a British standard anyway...
What is annoying though, is that the brake lights are actually 12V 5W from factory, which is a joke, explains why I could hardly see them. But if I install 20W ones like the indicator, I'll be scared they melt the wiring if illuminated for too long haha oh well, won't be my problem (hopefully)
PS Martin buy this car.
I may or may not have a sizeable collection of new globes you can pick up a selection of from me
8 hours ago, joeyjoejoejuniorshabadoo said:
Leigh, so after ~1 month of ownership how does it compare to be back in a lightweight but less powerful chassis?
Yeah it's good, handles crazy good and brakes are awesome.
It's cool having a new car with heaps of modern features with an old school feeling turbocharged engine & manual gearbox.
The turbo lag and when it hits makes it feel faster than what it is, which in a way is good for the street. Once I'm nearing the end of warranty will do some mods surely, but for now happy with how it is, maybe just get a catback exhaust soon.
370rwkw
160awkw? not sure :D
All good. I bought what I needed for $11.Still got a gremlin where with one of the rear parkers plugged in, it prevents the brake light on the other tail light from working... :confused: I've got a homemade CAD wiring diagram from online, but doesn't really help narrow things down.
/moneylinesaustralia
My $400USD venture into various crypto is now worth $570USD in under a month. Take that bank interest rates!
It's a bit confusing where values can be estimated/defined to USD, or altcoins against Bitcoin or Ethereum. So with bitcoin rising so fast, it looks like the altcoins are dropping, but against the USD they're increasing too.
Will you be providing your personal customer experience service?
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
