you forgot to mention with much much higher build numbers that is sure to help it hold it's resale value.
https://www.wheelsmag.com.au/news/1706/ford-mustang-sales-hit-new-heights-as-australia-becomes-top-market-outside-usa
yeah there's buttloads of them they'll be worth 20k in a couple of years and drift thrashers :D
nah I like em but just wouldn't buy one at this stage
Edited by UNR33L
I liked them but I like unique cars that you don't see much of
86 was an awesome little car but when you started seeing more of them than Commodores meh
Only problem with these well-priced niche market cars - every man and his dog.
Driving back from airport, Falcon F6, TT RS, 63AMG and a biker in t-shirt and shorts, racing each other Need For Speed style weaving through traffic on citylink at about 150km/h.
f**king flogs. No doubt get away with it too
I'd have smoked em all
  • Like 1
Whats finance rates like on a new car anyway? I paid cash cos VWL 2k17 800k baller club obviously
The mrs is looking for a new car and considering financing majority of it. Makes sense if the rates are shit all, gets you in the car sooner.
After 1 month of having a tenant move into my unit the hot water system starts leaking and needs replacement, garage gutter leaking into garage needs replacing fml LOL Costing me more than it's worth.
  • Like 1
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
