I think that era of accord is the way to go.
And that one comes with sick subwoofer
That was the only thing about the ad I didn't like.. Unless it's some old nob trying to appeal to young cats, in which case I'm fine with it.
I'll refine the search down to accords and see what's around.. Current search criteria narrowed my search down to 9000 cars... There's no category to filter out ugly cars
7 hours ago, Leroy Peterson said:
Also, i drive passed those country mcmansions on a big empty hill and assume its always galeforce winds up there, plus heaps of noise from the freeways.
And birds, if you planned to capatalise on R33 prices once americans can import them, why spend all this money on a barrys build?
The barry build was started before GTR prices went nuts; I'd already spent the bulk of it before considerations of selling. Truth be told I'll probably swap a stockish RB26 back into the car when I do sell, and move off the dirty 30 to a drag nut for not that much less than it cost. I mean, as GTR prices go up so do their parts...the 26/30 will probably be worth more than I paid for it, if not already. About 6k has been spent thus far; long block form with sump. Not uncommon to pay upwards of 10-12k+ for one assembled by a known workshop.
Found out how to make power with the STI, seriously though I wonder what point or power level it becomes worth an engine swap, surely a 1j, 2j, rb swap would cost you shit loads. Unless you're going for 1000hp +, just build the ej
Dont forget to like and subscribe.
Looking for an intake for 2009 Honda Jazz. Anything from a known brand is like $400 for a bit of silicone hose, MAF holder and air filter. But space too tight to make something up yourself. Honda mods be criminally priced yo
Usual mods are exhaust / intake / dyno tune at 18 psi good for about 200kw at the wheels, no Ford barra or coyote power i know.. adding flex fuel 230kw but decent torque increase
Edited by UNR33L
ok so need to do a service on my ute, decided to try out sparesbox.com.au as seems much cheaper than the usual places.
for over 50$ they have free delivery up to 15Kg
to get all the fluids filters and such I want was apparently over 15 kg (mainly as 2x 5L oil bottles) so was 30$ delivery.
so instead did 2 orders both with 1x 5 l bottle and some other stuff, ended up with free delivery anyhow and they now have 2x delivery costs....
good business model
Not expensive, just drop one in
  • Like 1
26 minutes ago, UNR33L said:
That's fair stupid of them not to pickup on it.
When is next deca? is it still a thing?
deca is dead. long live the new DECA
there is a new deca ....close to you cheap and fun.
Entries for SAU members have opened, non members tomorrow night. on track in 1 month from today
https://www.sau.com.au/forums/topic/474098-svm-round-1-metec-june-23rd/
hope that soon enough for you
edit: that's actually why I am doing an early service on the ute as will tow the s14 there.
  • Like 2
45 minutes ago, Leroy Peterson said:
New DECA sounds great. Super excited to see what can be done with the back track.
This might kick me into gear to get pulsar out.
Lets race!
I'll have to find a place to mount fire extinguisher in new car ?
Do they check dates? last deca I got through with an old one lol
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
