52 minutes ago, emts said:
I think your overestimating a stock cars speed.. and under estimating it's reliability
Whilst a STI is very quick on a road a stock one on the track just does not have the tyres/suspension to be corning hard enough to really carry enough speed to cause a problem.
plenty of people run STI's on the track and they have no probs car mags run them all the time.
your just  going to do a few 200 -> 60 slow downs, and a set of brembos will handle it fine.
your not going to be pulling low 20's or anything.
monitor your temps adjust your tyre pressure during the day (I assume STI have TPS as the stock imprezza does) and you will be fine,
Sandown is normally 5 lap sessions I would be doing 2 hot 1 cool down and then 2 hot to finish (you then get a cool down coming into the pits)
couple laps of the pits and don't put the handbrake on in the pit.
you are going to have lots of fun.
That's exactly what I thought, the magazines hammer them all day without issues.
I'll keep you all posted anyway with what happens :D
I'm expecting pads to basically be gone and tyres go mooshy after a while.
The car has giant front calipers it will be fine.
And also got that fluro green radiator ducting so extra cooling.
Will be fine. Maybe bring a hand held temperature gun to measure radiator temp/block temp after session.
  • Like 1
Contribution from my limited experience:
Brake early into turn one on your first flying lap to get a feel for it; people seem to underestimate how cooked their brakes can be coming onto the main straight. That huge kitty litter patch is there with good reason.
Flashbacks to Simons car going through kitty litter and ripping his FMIC apart ?
Making me wanna just do motorcycle track days again, much cheaper :)
Edited by UNR33L
if your intercooler is hitting the kitty litter in a WRX/STI you have bigger problems.
so flash back to my first ever track day
was with WRX club and was meant to be driver training, however I was only entrant so they just dumped me in with regular told me I was in a group with similar speed and just follow them. Note my car was very stock at time
first hot lap I was following a wrx to turn one saw his brake point so I hit it 50 meters earlier just to be careful...cue flying straight past corner and into kittly litter..one I finally slowed enough to know was not going hit wall look at mirror to see a MX5 flying backwards into the kitty litter right at me, so powered on out. no damage lucky.
went and tracked the WRX in the pits later, semi slicks, Big brake conversion and fully stripped out....damn it.
21 minutes ago, blah_blah said:
Anyone going to this?
If so come by and say hello ill be competing in Quake
Thought about it, I wouldn't mind running in the open forza competition with the v8sc
Not much else really takes my interest though
Edited by UNR33L
 I think last track day I did in a car was 8 years ago Winton in my 33 gtr
The centre caps on my wheels were plastic and melted off :(
What recording app do you use on phones?  I heard Racechrono is good?
Edited by UNR33L
52 minutes ago, blah_blah said:
Ayyyy ill be there Saturday
I'll try and make it down, just saw there'll be 5v5 CS:GO in the main arena which should be good
I'm guessing the place is gonna be packed
Edited by UNR33L
2 hours ago, emts said:
racechrono on android with a external 10Hz GPS receiver.
+1 for this.
That said, have used WITHOUT gps receiver, still gets pretty good/usable/awesome data. Would try it on its own first nowadays with updated/modern phones.
Yep.
First proper track day I did was Rexmas at Sandown.
Didn't kill brakes and tyres that day and it was only allowed to push it at 80% that day. But Platts managed to blew TMIC Y pipe and boost went from 18 to 25psi on 205 block...
1 hour ago, Count Grantleyish said:
Yep.
RIP
The more I read about the EJ the more I cringe
I mean the Focus RS was the other option ?
But the rumble is good!
Edited by UNR33L
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
