it fluctuates, but my 1080 & i7 8400 are churning out ~$100aud/month if left on 24hrs. That's with BTC price hovering like it has for the past 13 weeks. But since a recent update, seen a 20-55% increase in payout.
I think its important to come up with a gameplan for each cycle. I've learned a lot in the last 6+ months so hopefully can apply that next time and during the bear market.
Planning on buying a house later this year... so sadly will have to liquidate a lot. Using crypto as collateral for loans or mortgages is even closer than people think... I'm annoyed no one will accept anything other than house equity as collateral. That shit is sooo 1980's.
Cardano
'nuff said.
I like cardano as a project and wish them all the best, there might be money to be made short term, but when the project team dont give a shit about price, want to deploy it to very very poor nations, are academic focused, took 5-6 years to get the fundamentals where they wanted it, and aim to keep it as cheap as possible... doesn't spell well for long term investor gains.
  • 1 month later...
Best ad ever, the enquiries must be rolling in
Check out this 1998 Nissan Skyline GT-R V-Spec BCNR33 Manual 4WD.
https://www.carsales.com.au/cars/details/1998-nissan-skyline-gt-r-v-spec-bcnr33-manual-4wd/SSE-AD-7272590
  • Haha 1
100% justifies the asking price….
Makes me want to enquire to find out more.  It really got the juices flowing!
  • Like 1
Given benefit of the doubt, it could be one of these scenarios
Her: “You still haven’t sold that damn car yet; get rid of it; we need to make room for a minivan”
”I put the ad up…see! Just haven’t had any bites yet.”
  • 3 weeks later...
  • 3 weeks later...
On 9/2/2021 at 12:27 PM, Count Grantleyish said:
You buy?
That or the new RS3…which would be more practical…and more expensive…and not manual 🤔
Get RS3
They will make better racket guaranteed.
On 9/4/2021 at 9:25 PM, Leroy Peterson said:
no more subie? what about your efame?
Sold it just wanted a change, miss it though for sure. Took advantage of dat used market.
Working at car dealerships so seeing all the nice Audis come in tempted me away from the jap stuff for now.
Got an R33 again now for shenanigans, whats a good performance shop these days to make my R33 fast?
Edited by UNR33L
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
