  • 3 weeks later...
On 8/20/2024 at 4:03 PM, SKY031 said:
Do it.
I'm looking, so many trash R32s out there. Trying to work out if I want a "stock" one, or modified. There is a mint Nismo for sale at the moment. Just not sure I want to drop over $150k into one for something that will basically sit in the garage.
Himmy seems to be bringing in some nice cars,
ive had a few now and they all have issues- no matter how neat and tidy. theyre just old.
Yeah usual old brittle wires and hoses. Cracked vinyls and bubbled dashes. Everything you touch disintegrates. I think we’ve got to the end of life for a lot of materials used in the manufacturing.
1 hour ago, funkymonkey said:
Mad invite asshat.
woulda brought the GTS4 out.
I was taking a shit at the shop and decided to go for a drive on a whim after I saw pats story lol
Should’ve been thinking about your mates while taking shits. Unacceptable.
  • Haha 1
On 8/9/2024 at 2:58 PM, Mohsen said:
if you lads are keen we can probably get a group chat going with the OGs and organise stuff here and there
Do it.
Just do it.
Yeah both very true. There are some nice ones still out there that have had most of the basic work done to fix them. But they cost decent coin. To be honest in the long run I think its probably worth just paying a bit extra. There are only 2 things I really care about, no f**ked dash (rules out about 75% of them) and no worn / f**ked front seats (another 75% ruled out of the remaining 25%) so yeah, its like finding a needle in a hay stack. The other issues I can deal with.
Still have to rebuild the f**king rex too. Eldest has been pestering me for ages now to start working on it. Need to get it towed to GIR to have them get it running so I can work on the body.
I'll be down for a meet, will dust the mustang off and bring my son so he can wet his pants over the skylines. :D
Took him to KIR friday drifts last month, brought back some memories of the old days heading out to calder to watch it all. Was fun
would you like to be added to the messenger group?
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
