After owning this car for about 14 months its time for me to sell. I moved to an apartment with no car park and as a result the car has sat in my parents garage for about 6 months and I have driven it 3 times during that period. I took it to get a pink slip (because i forget that rego wasn't due til September) and my mechanic told me i had done 2 or 3000 kms since my last pink slip. Its a total waste sitting there.
I bought it off a forum member mid last year because it was the best looked after example I saw plus it came with some goodies. I have copy pasted a chunk of his for sale post because really little has changed.
Specs
'03 350gt V35 skyline (top of the range)
3.5L VQ35DE
6 speed manual
Brembo brakes all round
Half leather/ half swede seats
Bose Stereo system
Factory HID's
9XXXX KM ( will confirm next time I jump in it)
Mods
-Tananbe Coilovers
-Fujibitso stainless steel exhaust (stock extractors but from there back is aftermarket)
-Veilside Andrew Golt wheels, 19x9+9 and 19x10.5+5
-350z 'Rev up' Intake.
-Clutch apparetly Excedy HD, nice bite but not heavy for everyday driving
-OEM style badgeless grill
-Nismo Leather gear knob
-Clear side indicators
-Front number plate holder deleted and tow hook cover sourced
-Extended wheel studs installed all round
Pros:
Tyres are pretty new
Replaced the front brakes/pads and will provide rear discs and pads (EBC red from memory)
It gets regularly serviced and I will service it again in the near future before I turn it over
Insurance risk just got reviewed!
The bad
Body isn't perfect. The passenger side door has a scrape on it and there are scratches from when it was much lower. I raised it so I could get in my driveway
The front lower control arm bushes are a bit munted. I found this out when i took it to get a wheel alignment. This should cost about $300 bucks or so to fix and I have factored it into the price.
Rego is due in September
Price wise I'm after about 14k considering that there isn't much rego left.
Contact on cameronjpascoe at gmail.com or zero four 31679674
Please message during work hours or if you don't get through as I have uni at night as well.
Located campbelltown
Edited by The Panda
https://www.sau.com.au/forums/topic/458567-sydney-2003-v35-coupe/
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
