I thought it would be a good Idea to post one of these on here because I haven't seen anyone post anything about these turbos or anything related to this matter.
So right now my R32 GTST is undergoing work for the following parts:
TWISTED MOTION RB20DET GT2871r VER 1 Turbo
GODSPEED Forward facing Plenum
Tomei Outlet pipe to a 3" custom TurboBack
550cc Injectors
Boost Solenoid
Walbro 255 Fuel Pump
Tomei Fuel Pressure Regulator
ADAPTRONIC ECU tuned by XACT TUNING
So Far the plenum and turbo is going in and there were little things that I thought people should know going into this kind of budget build project:
1. The turbo is pretty awesome. For the price you can't beat what you get. I know it's a cheap turbo and people are going to say get a better turbo and whatnot, but I have a better plan rather than spending $$$ for a name brand turbo. So first off the turbo was 450$ and once the turbo starts to go I'm going to buy internal parts for it which is going to cost me around 300$.
As far as Install I'm having a 2" 90degree Cast aluminum Elbow Welded to where the stock elbow would be so that I don't have to deal with couplers.
2. The Intake Plenum is a tricky one for RB20s. Unless you have 1200$+ for a plazmaman/raw brokerage Intake plenum there really aren't much options for the RB20.
What I did was get a GODSPEED intake plenum. It was around 250$ on ebay, and once again I know people are going to bash for buying ebay parts, but this is a budget build. That and the GODSPEED plenum isn't that bad. The welds are extremely clean, and has ports for everything stock to be connected right up to it. ie. adaptable with the stock throttle body.
The only hiccups are the plenum's mounting bolts are blocked off so we had to drill it through so that the bolts can go in all the way. Apart from that so far there hasn't been any issues.
It should be done this weekend and next week I should be able to get this thing tuned with ADAPTRONIC which is one hell of an ECU for the price. Thank you XACT TUNING in AZ for hooking me up with the price that you did.
I'm going to post some pictures here soon, and Keep everyone posted on how this build goes! My Goal is 320WHPish. Wish me luck everyone!
Once it's all said and done I will most def let the RB20 Community know how it is and if it's worth it!
Edited by HanBear
An RB20 with an ebay turbo and a massive plenum like that, it's going to be a very laggy 300hp. But hey you knew what you were getting yourself into and seen to be happy with it so go for it.
Good choice ditching the SAFC for a real ECU, now you just have to do the same with the turbo ;)
  • Like 1
By the time you get the $450 turbo, $300 rebuild kit, and someone to weld the elbow on, its sounding like a $800+ excerise, +time off road to rebuild if it fails.
That's providing if the turbo fails parts don't go into the motor and kill everything.
Hypergear highflow can be had for under $900 (check current pricing). Proven results. Meets your goals. Bolt on simplicity.
Stock plenum would meet power goals, only real reason for a foward facing plenum is to make the bay look "neater" or reduce cooler pipe length. Can't remember ever seeing a performance gain from a FFP at that sort of power level on a rb20.
Fuel pressure regulator you don't need.
Tomei dump is nice, but not a "budget" option.
Your ecu is a popular choice and seems pretty well supported.
When I was looking at modding my RB20, I basically read the RB20 dyno results thread, hypergear thread, and kando thread. Absolute wealth of knowledge out there, from people who have done the same thing you want to do.
But looks like you've already got the parts, so best of luck.
^^^^^ This. Is. What. I. Was. Going. To. Say.
  • Like 1
As far as turbo I couldn't really find one that didn't cost under 1200 bucks new. I'm relatively new to the skyline and I found one that was pretty cheap and pretty good. I've seen the same turbo on some sr and rb series engine at the shop I bought it from. It's pretty good. That and building the internals and making a cheap hybrid I thought was a pretty good idea. Lol.
As far as the Tomei outlet pipe I got it for a steal of a deal so I couldn't let that down.
I've never head of hybrid gear highflow :(.
And me and my buddy are doing all the work. Welding and what not. He's a really good welder and he's already done the work on other turbos with welding on elbows so it's not going to cost me much.
After this I'm going to upgrade to a top mounted turbo in the future with a new manifold and what not. Thought this would be a fun thing to try!! :D
Thank you all for your inputs and I will most def keep all of you posted and pictures will come soon. As well as Dyno sheets and what not.
For the fuel pressure reg I thought I would need one and I thinks it's always good to have one. Lol.
Here's a little update. I'm still waiting for parts so at least got the plenum side done. Big thanks to my buddy cliff @rukigarage for helping me out.
I definitely like the way the forward facing plenum looks. :D once the rest of the parts arrive I should be able to install and Dyno next week sometime. :D!! I'll post the Dyno sheets and more updates and give you guys a more in depth of everything with pics.
Update #3
So my buddy Cliff did some fabrication for me for the ic piping in the intake side. And it looks so dope. :D
He also did some fab work on the intake itself. All in all I'm extremely happy with it. Next is the td06 going in!!!
So I decided to go with a td06 20g. It get in tomorrow and everything should be almost ready for tune.
Adaptronic and 550cc injectors next!
  • Like 1
Update #4 so the cold side ended up really nicely thanks to cliff @ RŪKĪGARAGE. All the welding came out pretty damn clean. And the turbo went in. Now all we have left is to connect all the lines, weld the 90degree elbow onto the turbo and tune it!!
post-139509-14398271670594_thumb.jpgpost-139509-14398271961706_thumb.jpgpost-139509-14398272252939_thumb.jpg
Update #5
So everything is installed and I drove it around not tuned and it runs really smoothly. I'm going to get it tuned with adaptronic/550cc injectors/boost solenoid. I will post Dyno sheets tomorrow!!!!!
Edited by HanBear
  • Like 1
    • I can also smell fuel in oil if that helps.
    • Hello, after engine rebuild(new cylinder liners and piston rings, arp headstuds, metal cometic tripple layer gasket, all new main/rod bearings) and roughly 100km made I did measure compression and it’s (1-6) - 80, 60, 90, 120, 110, 135. It’s rb25det series 1 - hydraulic lifters. Measured on cold engine. Didn’t check on hot due to overall car problems such as broken 3rd gear, idle issues, misfire etc. I did smoke test only on 2nd and 5th cylinder bcs soldering iron used with this method broke itself. So after setting cams to side - side 90 left/right angle I can see smoke coming off from intake manifold and turbo exhaust flange. 5th didn’t notice any smoke. Shop did head, valve etc job but I assemble it by myself. So I thinking about lifters. I don’t remember if they were soft or not it was long time ago. In my opinion I didn’t bleed them and they can be opened more than they should be. Can it be more likely possible? Or timing can be off by 1 teeth and can cause such weird compression? But if timing would be out wouldn’t it be like such big difference across all cylinders? Please help I’m so sad it happened.
    • Hey, yeah I really like the color. Only paint I'd rather have is KN6, but those are expensive. Right now I'm trying to get the car to the point where I can get it tuned to 370hp so the whole setup can be driven legally, and pass the next inspection that is already due anyway. Beyond that lots of rust fixing I'm afraid, winter project is most likely going to be a front end teardown and fixing the strut tower rust. I know these can be driven daily but I don't think I will do so anytime soon. Will post a build thread soon with a list of issues and futute plans.   Cheers
    • Wanted to reply to this topic. I'm in the somewhat same boat with our Stagea. I'm trying to install a different rear diff. The Stagea/Skyline uses mounts on top of the rear diff for the ATTESA pump. Any way you can relocate the pump? I did find this kit https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • So here's the deal, my wife picked up an S2 AWD Stagea. Super cool, clean car. Looks like the owner in Japan went track spec as it's got some heavy modifications including Exedy twin disk, tension rods, coilovers, GTR brakes, oil cooler & a Nismo 2 way rear diff. Now, cool mods for sure. But, she is just using this as a casual daily driver. The 2 way rear is AGGRESSIVE. It also has solid subframe bushings & poly diff bushings. So that doesn't help either. So far I've tried changing the diff fluid to the correct fluid. Even tried a little friction modifier. No help. This thing clunks, skips the tires & has some slight whine/NVH when driving. Might sound like I'm being picky, but just trying to find a better solution. Here in the states, it's impossible to find a Stagea rear diff. No luck. I do have a 300zx non-turbo diff. Same ratio, 5 bolt axles. On the Stagea, you need both front & rear diff ratios to match. This car is a 4.083. I'd like to just swap a normal rear diff into this thing. Nothing fancy. Even open diff is fine. She's not tracking the car LOL The difference is that the ATTESA pump mounts to the top of the rear diff. There are 3 total mounting points for the pump on top of the diff. With all this being said, what would be the best way to go about this? I could remove the Stagea diff & see if I could get somebody to possibly weld the 3 tabs/mounting points onto the 300zx diff so we could mount the pump on the 300zx diff. I could swap the internals from the 300zx into the Stagea diff but this is not in my comfort zone. Is it possible to mount the ATTESA pump to the underside of the car? Sorry for the paragraph. Just trying to figure out how to go about this. Any help is much appreciated! Stagea Differential - Note two top tabs, one bolt hole for ATTESA pump mounting   300zx Diff - No mounting tabs Also found this mounting kit ?? https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
