Well it doesn't matter so much as why the hell is it only putting out 400hp on 20lb.
But:
80mm afm's.
-5 turbros.
PWR intercooler.
256 degree inlet cam, 252 exhaust
Cleaned up head.
forged internals with new crank, carillo rods.
stock exhaust manifolds, ported.
Tomei dumps and whatever you call the pipes after that.
3.5" exhaust.
Generally stuff and done properly.
Edited by djr81
I take it that its been tuned and etc
Japanese branded against? If so did you remove the restrictor?
Good quality cat or even better gone?
The other thing that seems to be coming up a lot is crank angle sensors on the blink
Prior to the rebuild at one point it ran 450rwhp on 15lb with the same exhaust but different cams (Poncam B's which suck)
Was expecting something like 480rwhp. AFR's are 11 and a bit. Doesn't drive like its lacking ignition advance.
Cas was replaced 12 months ago.
Injector duty is well below 100%
Edited by djr81
Did you ask the tuner if he found any problems? You don't mention adjustable cam gears. RB26s respond well to adjustment of cams.
And don't be shy - who was the tuner and how long did the tune take?
What fuel pump do you have and how old is it?
Same exhaust.... Still. If it's 10 years old and had been bumped on-off the car I would want to be sure that a baffle hasn't corroded and come loose etc. Easy enough to drop it snd check. Ditto rag in cooler pipe.
I wouldn't jump to the conclusion that head and springs are a problem until you have done basic checks.
Tuner can't guide you based on how engine responded to fuel and ignition numbers?
Yeah I think I will have to start with the exhaust and cat and then pull the timing belt cover off it to see where the cams are at.
I only asked the local bloke to stick it on the dyno and see that it was ok rather than to tune it. He didnt do the tune that is in the car, that was done in Perth and I am starting to suspect it is less than complete. He pulled a bit of fuel out and said it gained eight or so horsepower. Didnt ask about ignition as the fail was doing my head in. But 70-80hp is alot to explain away by tune or strapping it down fairly hard (his other throwaway comment) or any other thing.
It makes good torque or atleast as good as it ever has just after the knee point in the curve when the boost flattens out it doesnt keep making power.
The previous number was 408 hp on a hub dyno with 16lb.
It has a Nismo fuel pump and the afrs are in the11's.
So you have a fully forged engine but won't pay $1000 for a proper tune!
If it had a decent tune last time it my not take that much to bring it up to speed but 70 - 80 hp difference in tune is entirely possible - even more. And if you haven't got adjustable cam gears put a set on first so that your cams can be adjusted.
  • Like 1
I never said that at all.
The point is that Perth tuners are a 2.5 hour drive from home and then I need a bus ride to get home. So there is the best part of a full day gone and its repeated to collect the car. Two days off work costs me $2k before I start with the mechanics bill. Plus the favours I need to get the thing dropped off/picked up etc.
The last time it was tuned it was supposedly done properly by a supposedly good workshop in Perth but they couldn't diagnose a stuffed boost control solenoid and gave it back to me with low boost and 409rwhp on a hub dyno. The time before that with a different Perth workshop was even more of a train wreck.
I fixed the boost controlelr and the purpose of getting run up on a local dyno was to check it over on the assumption it was otherwise ok, not to tune it. But it made four more horsepower for four more pounds boost. Dyno disparities aside that isn't exactly winning.
Its got adjustable cam gears but I always viewed them as a nice to have for a few more hp, not a 20% gain. Nor do I really expect to find 80hp from some more ignition timing. Hence the thread asking for likely candidates.
For now it is:
Pull the exhaust and have a look.
Put it back on the dyno with the front cover off the motor and look at the tune.
But I don't have great hopes.
Johnnilicite: What would you expect the timing map to look like?
Edited by djr81
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
