Hey guys
Usually I don't have a drama installing gauges
And I came up with this idea
Everything would fill up with water so I can't see a problem
But I want to retain the factory sender and the after market one
What about doing a t piece into the factory location
Cars an r32 rb20 btw
It's one thing for water to fill up places, but its another thing to get an accurate reading. What you really need for accurate readings from water temp sensors (in fact any temp sensor) is flow past it. In the factory locating, the sensors get this. The problem with your idea that I can see is that the coolant will flow past the fitting and not really into it. Therefore it will get heat soaked and show false readings.
Have a think about what I'm saying and it will make more sense.
The after market gauge I once had, had a metal in line adaptor that was fitted to the top radiator hose. Who ever fitted it cut the top radiator hose and then fitted the adaptor [think it was alloy] and used hose clamps either side. The temp sensor was screwed into the sidewall of the adaptor. Gauges were Blitz I think???
I don't run with water temp any more, just oil and exhaust temp and oil pressure. The standard water temp on the dash works fine for me.
I was thinking of doing that but the top hose is rather short and I also just bought a new one don't feel like cutting it up
I'm thinking of relocating the factory one to the bottom hose as it doesn't really give you an accurate temp anyways
Rather telling me if the water post radiator is cool
And screw the aftermarket one in the factory position giving me a more accurate engine temp.
Does this sound like a better idea guys
Edited by Peanut92
I'd use an oil temp gauge for engine temp, unless you're running with an oil cooler and even then its still better.
Keep the water temp so you know your car is getting good cooled down coolant.
IMO.
    • Man that dinner was such a long time ago....2010! I would only replace the rubber coolant lines with silicone these days; cheap, readily available and will last for ever. You will need new hose clamps though eg https://justjap.com/products/cooling-pro-silicone-engine-heater-hose-set-black-nissan-r32-gtr-rb26dett
    • I wouldn't look too hard at what they did with the R32 GTR in endurance racing in Australia... Lots of things weren't actually available from the factory in the way those cars ran them... Japan also followed what Fred Gibson was doing here with some of there endurance cars in Japan... Australia is also the reason for things like the Brembo brakes, and the change in the gearbox... And quite a few other tricks they used to pull. There's a few other SAU peeps still on these forums that will have heard the stories direct from Alan Heaphy, Fred Gibson, and Jim Richards when we were lucky enough to have a great dinner with them
    • For all the talk of "these parts are junk" I generally recommend OEM because it's really not as bad as claimed. I have never seen or heard of a case like the N63 where the oil returns completely clog with coked oil for example in ~10 years or less. Would it be nice if it were a straighter path? I guess, but most modern cars use a scavenge pump instead of a pure gravity return. Also the factory lines that would be relatively simple to convert to braided are generally speaking hardlines from the factory. I would consider braided line to be a regression, not an improvement. It's also been engineered such that all the hardlines have appropriate strain relief where needed. There's absolutely room for improvement, for example the HKS advantage heritage intake piping shows just how much can be done to make the turbos fight each other less in OEM twin turbo configuration and reduce compressor surge but it's rarely a simple/straightforward process. I recommend looking at what the group A/N1 cars did, generally speaking the changes they made were necessary and proven in endurance racing.
    • Yes, multi relays needed, and possibly a diode. I'm not actually going to think about it though.
