Yeah it was. I havent actually taken the car back from the workshop since being rebuilt. Looks like a problem since the car has been first started as we havent really put any kms on it
Maybe it's time to tear it down if you are 10000% sure you got all the air out
How did you say you bled it?
Yep that's the plan it looks like
Tried a few different methods.
- let it idle and keep the revs around 3 to draw in water into the motor.
- Kept the heater on all the time
- after a few mins, switch it off and let it cool down
- Opened the bleeder valve with the car off and with the car on until steady streams of fluid came out. Not once were there bubbles or broken stream. Water seemed to be in the head at all times from the get go
- Tried jacking the front up as high as we could so the radiator was higher than the motor and repeated the processes.
- tried having a bottle cut open with fluid in it, sitting in the radiator as we were idling and revving to see if it would suck more in. kept sucking in a lot and when it finally didnt want anymore, it stopped.
- Tried a method with the radiator cap on and the car on and letting air out of the bleeder valve, which none came out.
- Drove the car down the street, around a few corners and up a few hills to just see if we could push any air pockets out
- Used a vacuum machine to suck any air out, nothing really did
- had the car running for a few mins, stopped it, let it cool, tried letting air out, and repeated that process many times over a few days incase things needed to settle.
Nothing we did made a dent in the issue.
Yep it was, it would get worse and better as the temp rapidly cooled and threw out the hot water. As the motor got a burst of cooler water, the hot water coming out would cause disruption in the water in the bottle and move it around a bit
To be honest didnt check the overflow so i dont know
Did you have the cap open, with a funnel or bottle cut open pushed into filler neck, car running and undo bleed nipples? While adding coolant.
Exactly what we did. Def sucked in some fluid in. But just a steady stream coming out of the bleeder
Ok this might sound really, really stupid but its why i asked if its been freshly rebuilt.
Pull your thermostat back out, get a mirror and torch and under the thermostat they should have replaced (if they pulled out all your welsh plugs) a small welsh plug inside the block, its sits in the block under the thermostat, from memory its around 20mm big (guessing).
There is a very real possibility that they may have knocked them all out to clean the block and forgotten there was one in there, its easy to miss for someone who does not know RB's or got the apprentice to knock them all in.
Yeah i know its a pain in the butt, but you never know......
Your looking to see if this plug was put back in, its at the top center of the crappy pic i took, way down under the thermostat, behind in a second casting.
He is sure he put them in but was questioning to ensure that he did. Could be another reason he wants to pull the motor apart
But the above helps. It is something new to investigate at least! Thanks!
Just remember there are 2 open holes and a third one that the plug goes into.
One big one that the thermostat outside sits in with the casing over it held down by the 3 thermostat cover bolts.
One that the thermostat end rear/base sits over which is left open and is slightly bigger (by only a few mm) than the welsh plug under it.
Then the third hole which is the deepest and smallest, that one gets the welsh plug.....
Edited by GTRPSI
We just had 2 Koyo radiators fail from new in a 34 ,didnt have as severe issues as you ,but still did all the changes and checks you did as we didnt think it was a radiator issue .Both seemed to be partially blocked and both split and leaked with in 2 hours of driving ,put a new Blitz in and happy days ?
Did you have similar issues with temps rising and falling or was it just a constant rise and not coming back down?
it's interesting. Few other standard gtrs we were comparing with over the last week. The standard ones you could start up, drive out of the driveway and see it gained 10 degrees and heat would just slowly rise every min the car was on. Mine, well it just stayed cold for so much longer, temps wont budge, then all of a sudden a lots of heat!
Pulled the motor out of the car on Saturday. Going to pull the head off it hopefully today and get a good look at what is going on. Hopefully it's something little that has been missed!
    • I guess when I say it's a POS I mean.. the solution and the stuff has the capacity for maybe... 1 spot. You know, as a spot cleaner. What I really *want* is the ability to do an entire car, all upholstery, all carpet, mats, all seats, door card inserts, A pillars, roof liners, etc. In one go. I get lured by all the jank that comes out and think "I'd like to be able to clean to that degree"
    • I've got one (not the car one, the domestic spot cleaner one, which is basically the same jobbie) and have driven it hard for hours and hours at a time. Grimy sofas, 6' floor rugs, etc. I'd blame your specific example rather than the whole category. I haven't used mine in the car, because.... you know, it's my car. So there is no-one else's ball sweat in the driver's seat, there's no kid food/drink spills or hand prints inside because they've never had an opportunity to put them there. You know, basic, standard Skyline rules.
    • I normally run with I think a 10mm, and definitely use the second handle you can add to a drill. They hurt when they bins up!   For the crush tube, once all subframe is clear, I'd try some stilsons and see if I can get it to start to twist.
    • Probably because they couldn't, because the use of the variable resistor to create a "signal" in the ECU is managed by the ECU's circuitry. The only way that VDO could do it would be if they made a "smart" sensor that directly created the 0-5V signal itself. And that takes us back to the beginning. Well, in that case, you could do the crude digital (ie, binary, on or off) input that I mentioned before, to at least put a marker on the trace. If you pressed the button only at a series of known integer temperatures, say every 2°C from the start of your range of interest up to whatever you can manage, and you know what temperature the first press was at, then you'd have the voltage marked for all of those temperatures. And you can have more than one shot at it too. You can set the car up to get the oil hot (bypass oil coolers, mask off the air flow to oil coolers, and/or the radiator, to get the whole engine a bit hotter, then give it a bit of curry to get some measurements up near the top of the range.   On the subject of the formula for the data you provided, I did something different to Matt's approach, and got a slightly different linear formula, being Temp = -22.45*V + 118.32. Just a curve fit from Excel using all the points, instead of just throwing it through 2 points. A little more accurate, but not drastically different. Rsquared is only 0.9955 though, which is good but not great. If you could use higher order polynomials in the thingo, then a quadratic fit gives an excellent Rsquared of 0.9994. Temp = 2.1059*V^2 - 34.13*V + 133.27. The funny thing is, though, that I'd probably trust the linear fit more for extrapolation beyond the provided data. The quadratic might get a bit squirrely. Hang on, I'll use the formulae to extend the plots.... It's really big so you can see all the lines. I might have to say that I think I really still prefer the quadratic fit. It looks like the linear fit overstates the temperature in the middle of the input range, and would pretty solidly understate what the likely shape of the real curve would say at both ends.
    • I got a hand held bisssel one and it's a piece of shit. Doesn't work for more than about 5 seconds. So much so that I nearly refuse to believe any wet dry vac actually works or has enough suction to clean the carpet of a car. I'm discouraged as all the good ones are $300+ for an unknown result. I saw MCM did a Ryobi video where they use this thing: https://www.ryobi.com.au/products/stick-vacuum-cleaners/18v-one-hptm-brushless-spot-cleaner-tool-only Anyone have any experience actually using a tool like this when not paid to showcase it?
