I'm starting to put plans together to up the power in my R33 gtst. It has/will have a bunch or normal mods - bigger turbo, FMIC, boost controller, full exhaust, nismo fuel pump, Power FC etc.
The thing Im unsure about is that of fuel injectors. I had planned to go Nismo 555 as a step up from standard. I'm not planning to chase high power with my car, I'm just planning to make the most of my mods and get it tuned so its comfortable and reliable as my daily, but still has the power that these mods allow. That said, I'm wondering what life would be like getting the next size up injectors; 740s?
What's the difference in Nismo 555 vs 740?
For standard fitment, are they side or top feed?
and
Is a fuel pressure regulator something I would need in my modifications too, or is it unnecessary?
740cc man, 555cc you'll run out of injector very quickly.
I'm running 875cc stainless steel top feeds and at 343kW I'm already sitting at 87% duty.
Go top feed man, if you use half height injectors they will fit underneath the stock plenum easily without any silly spacers ot deleting hoses like other homo kits.
The difference is 185cc.
555 would be fine for up to 350kw ...I bought 550 Deatschwerks but today I would buy something more modern like a set of ID750s from Scotty. Get in touch with him and he will give you a good steer.
Get a more modern ECU if you can afford it too - otherwise Power FC will be fine.
For the price of nismos you can get conplete kit with everything you need to fit top feeds into r33 its what i just did 1000cc xpurts 40mm length ,rail,aeroflow reg,fittings,hose all off Scott.
Not a big fan of the 740cc side feeds, we have tuned heaps of both the 555's and the 740's and the 740cc injectors never tune up anywhere near as nice, they don't idle as well, and the cruise isn't as nice.....WOT is no different but the rest is.
If it was me and needed anything bigger than the 555's I would be doing a top feed setup with Bosch 1000's
I've tuned with the 740s before on a SR20 but not on a RB and didn't have real issues.. but taking note that per cylinder a SR uses more fuel than a RB hence idle/cruise might have been better as it required a higher duty cycle
  • 4 weeks later...
Take the majority advice dude, ditch the Power FC and go for something a little more modern(adaptronic, haltech), go with the bigger injector. I use 740cc Nismo injectors which are great. I've also used the 555cc nismo injectors. I had no issues with either car idling with my Power FC. My 740cc crack about 60% injector duty cycle so I have headroom for E85 but I will be cutting it OH SO CLOSE.
If you're gonna do it, plan it properly and do it right. I started modding my car years ago. Injectors have really come down in price and there are some more options for ECU's. The real pro's of a modern ECU are you can add inputs for mafless setups, flex fuel, other sensors etc. The pfc is a brilliant ecu but its outdated. A larger resolution can also give a tune far more detail and it can make the car feel just that much smoother.
If I was building my car today from scratch, none of the parts I have in there now would be used. They're good for their time and back then more affordable than what is available now. I also was lucky, I picked up my nismo injectors pretty damn cheap. Even cheap for todays prices. They've got up since I bought them.
With that said, I love my car :D
Edited by SargeRX8
FYI;
Nismo 555's are Side feed, and drop in to your standard rail. yes you will need a reg, anytime you change your fuel system from stock, as you will need to re-calibrate the pressure. ID1000 or EV14 injectors are top feed and require custom rail/collars.
sounds to me your pretty much doing teh same thing i did, on my first round of mods, with a very similar parts list. in which i have my old pfc and tomei z32 for sale atm, which got me up and over 500rwhp.
as for the comment about the 1000's being cheaper, not true. sure the injector itself is but its all the other shit u gotta change that adds in the price, and will ultimately cost you more. the nismos drop into the stock rail/lines etc job done. the bosche 1000's need a rail, collars, custom sleeves machined, .. then lines, and fittings and a decent return.. and u still need a reg either way.
    • I dunno man, that VX S with 200,000 k's is still hanging out for 1.5 I reckon the R34 is the better buy, personally.
    • Dang, doesn't even include on roads.
    • Only in a market where OBD was a thing. The rest of the world was quite happy to let the US EPA only affect US cars for quite a while. The* problem with datalogs is that unless you are very familiar with what every trace should look like, on their own and as an ensemble, you can and will see weird shit that can and will lead you astray, not realising that what you are seeing is the normal consequence of various transient inputs. *Really, "a" problem, as there are of course many other problems too. Look, these cars are so bloody simple that if it is missing or stumbling, the obvious thing is to break out the old mental diagnostic list and just go do all the things that you know you should. After proving that the plugs are clean and sound, ditto the coil stalks, coils, loom connectors, etc, and then making sure that there is fuel pressure at about the right numbers (while driving!, not while sitting in the garage free blipping it), then maybe you go looking at AFM voltages, manually testing the igniter, putting a scope on the CAS, etc. Then you're into pulling the injectors for a spray pattern look-see and perhaps a clean, squirting carby cleaner around the inlet manifold looking for leaks, and all the more annoying and esoteric, but still common as muck faults that these things have. I wouldn't ever bother looking at the trims, as they are usually bullshit on these old clunkers anyway.
    • Jousting sticks! Tell 'im he's dreamin!
    • GTR owners are wankers - 2025
