Hello everyone,
I need to figure out what is the power input that open the Variable Cam Timing, the Idle control valve the FCID valve that is activated on AC on.
Since I only have the engine and no ECU.
I think they are 12v inputs, but they may as well be 5v inputs.
Does anyone have any ideas ?
Regards,
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
