After finding out the distinct lack of seat rails available if you own a R31,R32,R33 and want to put in aftermarket seats in, I am offering a group buy for a set of copies which I will get a metal engineering shop to copy of the bride seat rails I am about to purchase for the recaros to go into my car. Recaro or no other company in Aus has any rails available either.
If you want to put in Recaro,Bride, Cobra, Sparco etc seat in ur line then you will need a set of these rails as the floor plan on the lines are at different elevations near the seat area and the drivers side seat belt holder is apart of the stock seat rails. You will not be able to adapt any other rails unless u custom cut and shut them, and then still the seat wont sit at the right elevation or angle and wont be as safe as these properly made ones I can get done.
If interested reply on here and then I can get a good price from the fabricator
  • Replies 69
I'm interested in drivers side R32 GTR rails.
Also for those considering aftermarket seats we can get good prices on them compared to recaros, bride and the like, from $530 for 2 seats:
http://www.hgeconsulting.com.au/raceworx/obx.htm
how mcuh is the railing?>....will it fit nicely into gtr with recaro seats
The floor plans on the r32-33 gtr and gts are the same so yes they will fit.
As for price, it all depends on how many people are interested in them, if not many then i wont bother getting an engineering company to fabricate them.
Duncan
No SPAM on this thread please :thumbsup:
Just be careful on the r31.. as I believe they are different.
And aussie and import R31 require different rails.
R31 aussie is definitely not the same as the R32 -> r33 jap stuff.
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
    • Hi all! Looking to relocate the battery to the trunk of an R34 GTT. I want to do it using as many stock GTR components as I can (including the harness protectors from the 34 GTR that run underneath along the chassis to the engine bay). So far I’ve purchased the battery tray from a 33 GTR, as the captive weld nuts are already there just asking to be used. There is also the slight issue of now having to relocate the ABS/TC/Fuel Pump Control ECU, which in GTT’s sits right above where the battery will then sit on the tray. Has anyone already achieved this, and if you have any pics that you wouldn’t mind sharing? It would be great to see how others have done it and where you put them, as there are countless holes in the parcel shelf panel to potentially use. Just trying to get some ideas bounced around, and to help uncover any potential problems I may encounter by  my choice of location. TIA for any help!
    • Brand was ard.   I also threw a brand new battery at it and beefed up the wire from the alternator to battery and added an extra earthing point from the battery
    • Evening all,       I'm replacing some bolts on my RB25 with probolt Australia bolts.       Does anyone know the following, m5 m6 etc 10mm 20mm etc       Coil cover   Cam covers   Plazamaman fuel rail   Front cover (timing cover)   Etc   Any help would be awesome   Or any lists anywhere
