  • Replies 69
I have passed this on to a mate to find a new shop to do it as the prices of the other place were to high.
If still interested please reply again on this thread for all those that had interested before so i can give a rough number to the shop willing to make them.
update
Cant get em made at a reliable place for less than $270 each, and since you can buy the original bride ones for around $295 each you are better off with going for the original bride ones.
supra
check your pm
  • 4 months later...
Guest
