Ask 10 people what's the best oil, you'll get 10 different answers.
Don't stress about it. A very small percentage of people are oil nazis, and they can go read bob the oil guy all they want.
For the rest of us, a reputable brand 5w-40 or 10w-50 is fine for 95% of drivers here.
https://www.sau.com.au/forums/topic/458795-oil-replacement/#findComment-7581640
thanks steve and alex , I have some info,the only reason I ask is im about to install a new oil cooler and oil pump and filter relocation kit.
engine oil
MOTUL 300v 20w 60
Castrol edge 10w 60
gearbox
redline mt 90
attessa
nissan oem d matic
diff
motul gear 300 lsd fluid
also royal purple has been recommended
https://www.sau.com.au/forums/topic/458795-oil-replacement/#findComment-7582007
I have MT90 is my S14 box, going to dump it shortly, seems to be too thick for the application
Hard to shift into second when cold, gets better when warm but still not as what I would have liked. Really sucks taking off from a set of lights and trying to force it into 2nd, while some daewoo is tailgating and trying not to crunch the gears
https://www.sau.com.au/forums/topic/458795-oil-replacement/#findComment-7582235
I basically went to autobahn grabbed motul full syn gbox, engine, diffs , coolant, everything, cost 500 got a 100 discount for spending so much.
I'm a MOTUL biased whore.
tracked all my litre bikes for years on the shit and never had an issue so I just stuck with it but there are many good full syn oils out there now days..
https://www.sau.com.au/forums/topic/458795-oil-replacement/#findComment-7583048
no worries skidza ,
any problem with filter relocation kits ?
as a mate said his motor rattles for the first few seconds ,until the pressure builds up ,
I thought there would be oil pressure in the lines.
https://www.sau.com.au/forums/topic/458795-oil-replacement/#findComment-7591346
