See Nissan got a little smarter on subsequent models and they determined that in order for the ATTESA all-wheel-drive system to come into play faster once wheel spin is detected, the transfer case should be preloaded (with hydraulic pressure). This meant that as soon as the pump was switched on by the controller, the system would already have significant pressure to dramatically reduce the time taken to engage the front wheels. We're only talking about milliseconds here but anyone who has driven both an R32 and R34 GTR on the limit will appreciate the difference.
I stole that from an article. Sorry.
There most be a faster way to engage the attessa 4wd system way faster. This is like such a big difference its ridiculous. Some would say us a electronic torque split controller. Is it possible to do it manually for the purpose of getting a better launch. What are some mechanical ways to have it done??
I was thinking of a hand pump to engage the system with some kind of pressure release at a certain speed. You would have a hand pump with a gauge and have it fully release to do a burn out. Then pump it up for the launch. Leave the line and at a certain speed have a release vavle let the pressure to to reduce drag on lets say cars without the potential to rip the tire loose in all gears. Like mine. :lol:
Am i crazy??
Hmm
Just had a wierd idea again. Is there a way to activate the attessa system using a button and let it go after the launch. Just to have it in full 50/50 split off the line. ????
This is the rod between the piston and fork. If i mod this to be an adjustable unit. Im thinking it can compensate for a worn disk. What you guys think
I think it would be like replacing the pressure plate on a clutch without replacing the driven plate. It might improve things in the short term but wold soon wear out what's left of the driven plates. However it would be relatively easy to try - certainly easier than transplanting the whole attessa system from an R33.
Local tuner Glenn Suckling built a 7 second R32 and says he had 3 computers controlling the awd but I suspect it took many thousands of $$$ as well as a lot of time so probably not an example for you!
http://www.speedhunters.com/2013/05/7-second-itch-thegds-motorsport-gtr/
Im saw an r33 gear box for sale. But dont know how to identify a r33 box. But that wouldnt be the solution. The reaction time would still be laggy comparing to the r33. Unless the preload is in the case and now created by hydraulic pressure. ???
Im reading these threads. Leaning hard to fullrace ets extreme. Still need to understand the system tho. I love the launch from a r33. I have most of my money in my r32 gtr and need to get it off the line if not equal as my r33 even better.
Read the link to Glenn Sucklings car I posted above. It refers to him manually pumping up the awd on the way back to the line after doing a 2wd burnout.
Thats simply what i want. Unlike him im far from 1628hp. So i wont need the 4wd all.the way down the track. But im envisioning the set up ill need to do. Ill just need full 50/50 for 2 gears. 1st and 2nd. Then i can have a electronic valve at the hit of a button release the 4wd. For less friction and more rwd movment. So ill plot it out. Just one thing. Whats the max pressure needed for full engagement. I can do this.
Ok let me take a few moments to explain what im thinking.
I want to retain the factory system and have a manual pump up system. So ill send the attessa line in the car with a bottle valve. This valve will separate the factory system from my manual system im going to set up on the other side of this bottle valve. (Towards T-case.) All the mods happen here. Im going to use a 240sx hydraulic ebrake setup to pump it up. Im going to have a pressure release valve in line so i cant over pressurize the system (will need to know the max attessa pressure for full engagement.) Next im planning on this pressure side to T-case have an emergency electronic release valve . Im planning on having some kind of computer at predetermined speed engage. Letting the attessa system bleed back to resivour. I will have one way check valves stoping the pressure to interfere with the manual pump when the valve is open for normal operating.
Hope its doesn't sound crazy. Lol. Ill draw it out on the weekend.
Ok. I got greenline to supply the disk to me. And ill rebuild the transfercase.
I just finished installing a r32 gtr attessa pump on my gts4 after i found a leak on the pressure sensor. First it was a hose i changed that clean everything. Next after a day of driving i found more oil on the diff. So i pulled the whole diff from the gts4 and replaced the pump with the whole unit from the r32 gtr. Ill post back the results. Soon.
I guess you are using this for drag racing use only, for circuit or rally use there are a range of electronic controllers that give excellent results.
For drag use I've either seen custom system like you are looking at, OR, HKS used to make a controller for drag racing that provided a fixed split.
There is nothing wrong with the mechanical system for drag use, you just want it to operate at a different time....so the right computer is all you need
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
