Hi Guys,
I've replaced a couple of timing belts before, but this is the first Gates one I've done. There's a noise coming from the cam gear area which I think is the noise of the belt teeth against the gears. I've heard the Gate's belts can be noisy but this seems pretty excessive and I'm thinking I might need to loosen it up a bit.
Can anyone confirm?
Cheers.
https://www.sau.com.au/forums/topic/458823-timing-belt-noise/
Should point out the idler and tensioner were replaced at the same time, along with the water pump. Prior to all this there was no noise from the old belt!
You got spacers for the cas? Seeing as not running the cover?
Yes the CAS has spacers, it's also only temporarily removed for diagnosis of the noise.
Edited by nicr4wks
It does sound like a humming of the belt teeth but the sound quality makes it hard to distinguish. I've heard a/c idler bearing make the same sort of noise when they're on the way out but you say it's up at the cam pulleys.
How tight is the belt?
http://www.sau.com.au/forums/topic/397602-how-to-replace-a-timing-belt-202526-pics/
As described in this guide, I can get roughly 1/4 turn out of the belt. It doesn't feel overly tight.
That method of a 1/4 turn isn't the most accurate. There are too many variables that can change like hand strength, how you hold the belt when you twist and if you can position yourself to get better leverage on it.
The best way I was taught and I feel its the most consistent is to pull the slack of the belt in between the cam pulleys so the rest of the belt is tight. The slack inbetween the pulleys can now be measured. Putting a ruler behind the belt it should only have about 6mm movement, that's +3, -3mm from centre.
Loosened up the belt last night, noise gone!
Dobz method seems pretty solid, I also found the belt "feels" the tightest between the two gears, I guess this is due to it being the shortest run between two points.
my recent squeal once car warmed up turned out to be the tensioner bearing and possibly the gates belt which was on the car already which doesn't flex as well as the original one so some excess tension was put on the bearings causing them to squeal due to the expansion of the engine as it warmed up something to think about
Thats just the killer wasps!!!
Thankfully mine doesn't make that sound......when I did it I just ordered a kit for the water pump, idler, tensioner, and belt. Belt that came was a Gates........I didn't think about it, but prob should have requested OEM.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
