Hi Guys,
I've replaced a couple of timing belts before, but this is the first Gates one I've done. There's a noise coming from the cam gear area which I think is the noise of the belt teeth against the gears. I've heard the Gate's belts can be noisy but this seems pretty excessive and I'm thinking I might need to loosen it up a bit.
Can anyone confirm?
Cheers.
https://www.sau.com.au/forums/topic/458823-timing-belt-noise/
Should point out the idler and tensioner were replaced at the same time, along with the water pump. Prior to all this there was no noise from the old belt!
You got spacers for the cas? Seeing as not running the cover?
Yes the CAS has spacers, it's also only temporarily removed for diagnosis of the noise.
Edited by nicr4wks
It does sound like a humming of the belt teeth but the sound quality makes it hard to distinguish. I've heard a/c idler bearing make the same sort of noise when they're on the way out but you say it's up at the cam pulleys.
How tight is the belt?
http://www.sau.com.au/forums/topic/397602-how-to-replace-a-timing-belt-202526-pics/
As described in this guide, I can get roughly 1/4 turn out of the belt. It doesn't feel overly tight.
That method of a 1/4 turn isn't the most accurate. There are too many variables that can change like hand strength, how you hold the belt when you twist and if you can position yourself to get better leverage on it.
The best way I was taught and I feel its the most consistent is to pull the slack of the belt in between the cam pulleys so the rest of the belt is tight. The slack inbetween the pulleys can now be measured. Putting a ruler behind the belt it should only have about 6mm movement, that's +3, -3mm from centre.
Loosened up the belt last night, noise gone!
Dobz method seems pretty solid, I also found the belt "feels" the tightest between the two gears, I guess this is due to it being the shortest run between two points.
my recent squeal once car warmed up turned out to be the tensioner bearing and possibly the gates belt which was on the car already which doesn't flex as well as the original one so some excess tension was put on the bearings causing them to squeal due to the expansion of the engine as it warmed up something to think about
Thats just the killer wasps!!!
Thankfully mine doesn't make that sound......when I did it I just ordered a kit for the water pump, idler, tensioner, and belt. Belt that came was a Gates........I didn't think about it, but prob should have requested OEM.
    • Hey y'all! I'm curious about how y'all go about widebodying your cars. I noticed that when running a square setup, my front wheels are a bit more tucked in than my rear wheels. Not by much, maybe 5-10mm. This leads me to wonder - when I widebody, should I use narrower front flares and wider rear flares? I found a set of 40mm rear flares that I really like, and was thinking of pairing them with some 18mm front flares, but I don't want the car to look strange. How have others done this? Note, I'm in a sedan. Thanks!
    • And if it was anything other than an auto tranny part, it might be a problem. But seeing as all auto trannies belong in the recycling bin, it's fine.
    • I have an R32 Fenix rad. It is good.
    • All the schemas I can see, indicate your typical setup of ATF 'cooler' (read: heat exchanger) in the bottom radiator tank..ie; https://nissan.epc-data.com/stagea/wgnc34/5413-rb25det/engine/214/ ...but I can prattle on a bit here. These trannies have a thermistor in the sump ~ the TCU reads this and 1. bumps the line pressure up when the ATF is 'cold' and 2. prevents the TC lockup clutch from operating, until the ATF comes up to minimum operating temp (keeps the ATF 'churning' through the TC so it heats up quicker) -- trigger point is around 55C. In these conditions, the engine coolant temperature rises faster than the ATF temperature, and also helps heat the ATF up, which is why it's best to think of the in radiator tank setup as a heat exchanger ; the heat can flow in both directions... ...with these trannies, the 'hot' ATF comes out the front banjo bolt, flows through the cooler/heat exchanger, and returns to the box  via the rear banjo bolt. This gets a mention, due to the wildly different opinions wrt running auto trans fluid coolers ~ do you bypass the in radiator tank altogether, or put the cooler inline with the in radiator tank system...and then, do you put the additional cooler before of after the in radiator tank system?... ....fact is the nominal engine operating temp (roughly 75C), happens to be the ideal temperature for the ATF used in these trannies as well (no surprises there), so for the in radiator tank system to actually 'cool' the ATF, the ATF temp has to be hotter than that...lets say 100C -- you've got 25C of 'excess' heat, (slowly) pumping into the 75C coolant. This part of the equation changes drastically, when you've got 100C ATF flowing through an air cooled radiator ; you can move a lot more excess heat, faster ~ it is possible to cool the ATF 'too much' as it were...(climate matters a lot)... ...in an 'ideal' setup, what you're really trying to control here, is flash heating of the ATF, primarily produced by the TC interface. In a perfect world, wrt auto trans oil cooling, you want a dedicated trans cooler with builtin thermostatic valving - they exist. These should be run inline and before the in radiator tank system ~ when 'cold' the valving bypasses the fin stack, allowing the ATF to flow direct to the in radiator tank heat exchanger, so it works 'as intended' with helping heat the ATF up. When 'hot' (iirc it was 50C threshold), the valving shuts forcing the ATF through the cooler fin stack, and onto the in radiator tank heat exchanger...and you sort of think of it as a 'thermal conditioner' of sorts...ie; if you did cool your ATF down to 65C, the coolant will add a little heat, otherwise it works as intended... ...the 'hot' ATF coming from the front bango bolt, is instantiated from the TC when in use, so all/any flash heated oil, flows to the fluid-to-air cooler first, and because of the greater heat differential, you can get rid of this heat fast. Just how big (BTU/h) this cooler needs to be to effectively dissipate this TC flash heat, is the charm...too many variables to discuss here, but I just wanted to point out the nitty-gritty of automatic trans fluid coolers ~ they're a different beastie to what most ppl think of when considering an 'oil cooler'... /3.5cents
    • Been a busy but productive day. Axle and hubs acquired. All fitted up after a bit of modifying. Need to sort out wider mudguards and running light reflector covers but other than that the trailer is gooood to go !!
