The Jotech Stage 6 S ('S' for 'Street') is a 1200HP monster.
I'm in love with the carbon brakes! And, check how factory the engine bay looks. Theres no way I'd expect the figures that it has.
Have a look at the pics below, amazing craftsmanship on the custom parts. This car looks incredible!
What do you think?
Maybe you want the 'R' version with 200HP more?
  • Like 1
https://www.sau.com.au/forums/topic/458837-1200hp-jotech-street-gtr/
It's nice and all, but for some reason it's just...I dunno.
There's so many 1000hp+ GTRs being churned out now that they leave me a little cold. I'm probably on my own here but what would grab me more is someone putting out a GTR that has lost about 400kg in weight but is still street legal and a nice car to drive on a daily basis. I don't know how much there is to lose in an R35 but 1740kg is one huge bish. I guess with the way the safety nannies are these days it's easier to build muscle than lose fat.
Having said that, if I woke up tomorrow and it was sitting in the driveway I wouldn't be terribly upset.
  • Like 1
"MUUMM!! I SAID I DIDN"T WANT THE JOTECH! NOBODY LISTENS TO ME IN THIS HOUSE!!"
  • Like 2
I don't often make comment on these forums but for this car : -
Looks like someone sat down and had a hard look at styling to make it more eye appealing, which to me looks to have worked.
A few old terms comes to mind :
"looks like its doing a hundred miles per hour just sitting there" !
"It doesn't have to try"
"talk softly and carry a big stick"
To name a few.
What's the 'R' version retail for ?
Because if its less than the 600K Nismo Juke in a previous post, I'm gonna cancel my Juke order ! ! ! !
Does that make you a lurker?
To name a few.
If this soft little Street build is $95k I can only assume it costs between that and $130k or so?
Surely you'd still need the Juke for track days while the GTR was the daily?
  • Like 1
Yep I've been know to lurke around a bit !
So after canceling my Nismo Juke order I'll now get 4 Jotech GTRs and have 80k for fuel !
How's that sound ?
I think I'm gonna regret canceling the Juke order though .................... .. .. .. NOT !
I think it's 95K for the kit... soooo how much are GT-R by them self new/second hand? Maybe you can still buy 2 though...
The attention to detail in this compared to the many other 1000+HP GT-R's is makes it that little bit special still...
Wonder if 1200HP will make auto not boring.
Bloke on whirpool fourm reckons he has a alhpa 16 package GTR with 1000KW..... Who never takes it above 3k as his not a hoon
Think on the the boys on here also on that site verifted he is the actaul owner of said car
so yer 1000hp is nothing these days.....
Id build one too if i had the cash
Ole mate droped $150,000k on mods to get 1000KW, even then had to updage cooler and tubrbos again
    • I'm pretty sure if it's considered a gasoline powered vehicle you have to do certification against a fixed, very expensive certification fuel.  If you add two precats and then replace the main cat with two cats back to back you can get an RB26 to do 0.24 g/mi HC, 1.6 g/mi CO, and 0.3 g/mi NOx on the FTP-75 drive cycle. Found this out courtesy of California's laws at great expense. Divide by 1.61 to get g/km. So even with extra cats + precats you're blowing past the NOx limit by probably 2.3x. Probably the only way to get an RB25 or RB26 to meet euro 4 purely from an emissions per km standpoint and not durability/OBD2 requirements is retrofit at least intake side VVT, clearance the pistons to allow the full 50 degrees of advance so part throttle EGR can be maximized, and change the wastegate control from conventional 7 psi spring for example to one that is always fully open if the wastegate line is at 1 atm or higher and only close it in response to vacuum. See BMW's N54 engine as a reference for how this works. You would need to find space for a vacuum tank to function as an accumulator in this system. That way you can avoid any heat loss to the turbine as much as possible during cold start to heat the catalyst faster. Then find some way to eliminate as much as possible cold start enrichment to light off the catalyst rapidly. Maybe secondary air injection if there's no way to avoid cold start enrichment. Close coupled catalysts in the downpipe are probably necessary. I would also probably swap to EV14s, pick something with the correct spray targeting + dual cone pattern for the intake manifold you're using. EV1 style injectors to pass anything resembling modern emissions requires a very annoying air assisted injector system to break up the droplets at part throttle/idle which still doesn't work that great compared to just having smaller droplets from the injector to begin with. Realistically, you're probably going to be financially ahead if you just pay the fines instead. Or don't drive it into the city center. There's a reason why Nissan never bothered to even attempt certifying an RB for CA/US emissions. The VG30 needed external EGR on top of NVCS to pass in the 90s. Doing all of this work is also distinctly expensive and you're going to struggle to find anyone who is remotely interested in helping.
    • I remember those, people use to steal them to make bongs.....
    • IIRC, it only cost me a couple of hundred dollars to get an Liverpool Exhaust to fabricate a custom stainless resonator for me to fit in the available realestate that I had under the car I actually watched as they did it, took about 1 hour to cut up the material, tig weld the body of it, and then add it to the exhaust  4"in and out, with a packed 5" body, that was about 12" long In the end, it is some blindly simple sheet metal work for an exhaust shop, and some welding
    • Highest combustion temperature is achieved at 14.7:1. (or, I should say, lambda=1, because 14.7 is not constant for all fuels). NOx increases exponentially with combustion temperature. So it is in the engine designer/s best interest to find a way to operate at lower than stoich max temperatures if they want to minimise NOx. If you want to minimise CO, you really need to run at least 14.7:1. Any extra fuel can realistically only ever report to NOx. O4 HCs if you are sufficiently sub-stoich, or if the engine's fuel-air mixing is up the shit. All of this presumes that the catalyst is not doing anything, of course. In reality, the cat is there, it is doing things, and how capable it is of eliminating either NOx or CO will depend on its age, quality, design, operating temperature, and how much the engine/ECU is designed to help it along, with fuelling strategies, air pumps, etc. And of course, RBs, even those with very capable aftermarket ECUs, usually don't have anything to help. They are just tuned to make power.
    • It's... way cheaper than what SP have on their website? I can only imagine if I say "can you make this muffler, but entirely different dimensions outside of the spec you offer as customization on your page" it would get even more pricey. I was looking at their race mufflers or their 'ultra quiet resonators' which are just smaller mufflers. They start at $166 USD which is $264. SP mufflers resonators start from $299 and are too long/not wide enough/can't be made short enough.
