definitely 100% not -5s, they came along about 15 years later.
there are guys on here who know what they ran for sure, but I'll bet the were big old modified bush bearing things in the original/factory housings. The R32 production Nismo and then N1 models had big bush bearing turbos and I'll bet that's what they started with.
We have to run the original turbs for racing rules and they are nasty, old fashioned things. They spool as slow as a -5 but only give the power of a -7, about 250kw at 12psi
BTW, I note the GCG website says "This Turbocharger is the turbocharger that was fitted on the Bathurst Nissan Skyline R32 GTR", and I still bet it's not true
oh I should add, the most recent race magazine had a long interview with Fred Gibson and it mentioned something about the turbos there....pretty sure it related to modified thrust bearings which also means it would have been bush not ball bearing turbos.
the magazine is a great read for anyone interested in the Gibson cars history
judging by the power it was making it would be fair to assume dash 5 spec but with bush bearing.
Conventional wisdom is that the wheels are an older crappier design. Hence Duncan's comment about -5s coming out 15 years later.
Yes, they were running Nismo LeMans Turbos 14411-RS581. A Friend of mine has these on his R33 GTR.
Journal bearings, rated up to 640hp (flywheel hp). Bit laggy, but still nice Turbos.
Edited by GT-R David
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
    • I have seen enough fire and brimstone from TSBs about roloc disks causing spun bearings that foreign object contamination is top of mind for me. For sufficiently large particles you might be right but usually it’s a distribution of debris and some of the larger particles can also break down and shed bits. If local shops report RTV contamination in a turbo is enough to wreck them I’m taking zero chances if I can help it.
    • Ask and ye shall receive! (eventually... ☺️) https://www.goo-net.com/usedcar_shop/0170208/detail.html
    • Weird ! Same Same with mine. Autoexcel in Bonnyrig is your friend !
