Hi guys, I'm new to SAU-read a lot of your posts though & very helpful. I'm currently waiting to import Black R34 gtt in Auto(yes I can drive manual though prefer Auto slightly more) & I'm wondering if you guys know the maximum potential of an auto r34? Planning on modding it with all usual suspects eg 3" cat, intercooler, new ecu + e85 & upgrade transmission etc. what could I expect -max hp wise??? Thanks in advance
https://www.sau.com.au/forums/topic/458916-max-hprwks-for-r34-gtt-auto-manual/
The potential of a stock box? Not much more than stock power (with a tune)
Potential of a box with $3,000 spent on it? A lot more than stock power.
Don't chase 300rwkw+ with a factory auto, you're gonna have a VERY bad time,
Thanks guys. I sold my N/A r34 because I'm now ready to chase high HP. I have a performance guy/garage that I'm close with in Northern Melbourne & yes I will be going bigger turbo, maybe Garret. Just need to decide on tuner. Just need to confirm R31Nioid, if I upgrade "slush box" (auto haha) then I can chase 600-700 hp at flywheel? Thanks guys
Yes
Greg managed 400kw from his 34, but it is a built 2.8 with a built auto.
I would be looking to keep it around 300kw, for auto longevity, but it will need a valve body upgrade and large trans cooler at a minimum.
I have few grand to star Gtstboy but doing tax soon & expecting descent return as industry I'm in (not porn industry but am considering it) ha. Also Scotty- is Gregg's an rb26 stroked to 2.8? And sorry(I'm no expert) but what is a valve body upgrade?
I don't think there much money in the porn industry for a male , unless your planning on man on man..
cheers
darren
  • Like 3
It wil be fine..its a R34 auto...even if it makes 400rwkw, half the pulls it will only show 300ish..lol, then 250, then 350, then whatever the f**k it wants..lol
cheers
darren
Edited by jet_r31
  • Like 1
Nahhh Darren, no man on man here mate!!! Sorry to disappoint haha. Anyways, so Darren do autos pull all over the shop in kws? Ps. I will have more than 2 grand for modding, just over a few months or so. I really don't want to go manual-but if huge difference in kW capabilities then maybe think about it. Or try rb25/30 on auto with built box
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
