Your plan sucks.
ps. Thanks for not being TOO direct in your answer/opinion(that's me taking the piss now). A simple "maybe not a good idea" or "too costly" would have been sufficient. Edited by MR PHATT
Thanks for the tip.
My thoughts are this atm=import clean r34 gtt-auto, mod to the max, if still having issues with trans box by start of 2016 then convert to manual. Any thoughts? I know manual conversion is pain in the a$$, but any one have price estimate?
This is literally the worst idea on the forum in terms of start to finish
I'm going fishing, should I get a manual reel or an auto? And what should I catch?
PHATT you shouldn't ask ppl to help you plan, you should have a plan and then see what is wrong with it.
I'd be more concerned about turbo, IC, computer, dump/exhaust, injectors, pump, brakes, suspension, etc etc...........Theres $10K in that alone.
Your a long way away from maxing out a GTT in manual or auto TBH. Work at the basic things and get them sorted first.
No wonder they are razzing you, its these sort of threads that make their day.
  • Like 2
true & thanks
Ok, ok, guys I know I went a bit off track & probably deserve a bit of s$&t stirring at the end, haha. I'm bidding on car later tonight(think manual) & have another in Vic I'm viewing(auto) on w/e. Both gtt. Going back to my original question=I just wanted to know if autos & manuals had similar hp capabilities, yes Ben & Hadouken "Mod to the max" capabilities haha? To help me decide which one
as soon as I posted that last idea I regretted it, was bad idea. Now knowing you have 400rwkw auto, & how much you've spent, I know not good idea at all
It's very easy to poke fun and have a lols at others who are just starting out and asking (what to more ... learned posters) can be silly questions
When the truth is you're likely just enthusiastic and excited and looking starry-eyed into the future of a nice well sorted high HP enjoyable skyline
well, let my jaded, aged eyes be the voice of reason and say OH SHIT SON BUY A f**kING MANUAL.
Better yet, buy someone else's project.
The way you're going about it is all wrong, has nothing to do with auto or manual.
  • Like 1
Cheers Kinkstaah. I am excited & realised I am jumping the gun. Was just so happy to sell N/A 34 & jump in to turbo. I understand it's a long (& expensive) road now.Taking all on board, thanks. Ps. Last import looked I had to say no as had a Nismo S tune body kit(did no like front bar) & big ass wing, was disappointed. I am now looking at others projects also.
At least you're selling the N/A and getting a turbo.
Do the smart thing and read read read. There's a clear upgrade path almost everyone follows on a long enough timeline.
Going to that point directly will save you many tens of thousands of dollars and years of labor and pain.
It could be argued that no one would do that/see the value in it until they've already done it the hard way once first though.
  • Like 1
N/A got sold. Will do Kinkstaah, & have been trying to read through as much SAU threads as possible & will continue to do so. Thanks mate. Ps. A bit off topic but if anyone in Vic & in to Muay Thai & mma-on 22/8 at Doncaster will be a few of my training partners & friends fighting. Will be good night & will be good to meet some of you guys
Edited by MR PHATT
sorry fights are in Kengsinton-Melbourne Pavlion.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
