Nahhh Darren, no man on man here mate!!! Sorry to disappoint haha. Anyways, so Darren do autos pull all over the shop in kws? Ps. I will have more than 2 grand for modding, just over a few months or so. I really don't want to go manual-but if huge difference in kW capabilities then maybe think about it. Or try rb25/30 on auto with built box
Just so you're aware a built auto box is around the $3-4K mark just for the box and that's generally on exchange basis.
For what it's worth I wouldn't bother with a stock box, either plan to build one from the outset or buy a manual car. I've got an early model RE4R01A auto box behind a 25/30 making 180rwkw but a lot of torque (lucky to be 300hp at the flywheel) with a shift kit and the box lasted 2000km before destroying the brake band. A later model RE4R01A like what comes in the R33/R34 is a little beefier with wider bands but it'd do the same thing eventually. I picked up a stronger RE4R03A and will try that with a shift kit but if it dies I'm putting the 25DET manual box in that's sitting under the bench as I can't justify sinking 4 grand into an auto box.
Cheers XR Pilot. But damn...3-4k for 2'000 km. it's a little disappointing to hear & only 180rwkw(sorry no disrespect XR). I was hoping for a lot more, like "Satanics" r34 project-I know it was a rb26/30 but still he kept it tip tronic & hit high hp. He did have hiccups though
Im not disappointed, i like vags..
Just trying to explain to you that wilst you may be able to have the money to modify the car by doing porn, you will also probally give up the right to float wilst swimming to get it..
And the autos suck..stupid f**king lock up converter is shite ,get a th400 or glide
cheers
darren
Edited by jet_r31
Just to be clear - that was a shift kitted STOCK auto that lasted 2000km - which is why I said plan on getting a proper built auto or just get a manual car. Also it's "only" making 180rwkw on 9psi on a STOCK R33 turbo. The car was built for daily duties and I have no doubt it'd be far quicker than a 300rwkw RB25 in point-and-squirt style traffic driving. It makes over 100rwkw at a bit over 2000rpm.
I haven't read back to see if it has been asked already but what are you trying to build the car for exactly? Drags, drift, circuit racing, daily driver? Not trying to be harsh but you need to figure that out before you a) spend any money and b) decide you need a 600hp auto Skyline.
cheers
darren
hey Darren, now I know what you're talking about, powerglide & th400. know them as 2 & 3 gear upgrades. How are they for Street driving ?
Are u looking to sell by any cance? Colour, kms, condition???
I had considered selling the entire box and transmission setup if the torque converter I am getting built doesn't end up doing what I want the car to do very well
(someone may want it for a different application, i.e drag)
But in all honesty, get the manual
If you would like to me expand on it, you should really, really, really get the manual.
To expand further, the gearbox has cost me closer to 10K to get it to where it is, which is good, but unless the TC from TCE makes it better than a manual (arguable!) you're at least, least, least spending 10K to get to the level where a $0 manual gearbox is at.
get the manual
To find out floor it till it swings a leg out of bed!!! Then back off 10% to be safe!!!
A manual RB25 can take 300rwkw and still be reliable. A NEO will - superior head - do a bit more.
Having said that I have now very likely angered the gods and mine will stop suddenly sometime soon.
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
