Ive just got a 25det neo running in my stagea, but theres a knocking coming from the intake cam when the vct solenoid isn't open. When its idling up until about 1400rpm you can hear the knocking but when the vct opens, above 1400rpm, the knocking goes away and sounds mint, ive tried replacing the solenoid with another one but to no avail anyone had this before?
https://www.sau.com.au/forums/topic/458930-rb25det-neo-vct-knocking/
So i changed the cam gear with one of a 25de neo, and i noticed that the cam gear was bolted up differently to the original one, the de one was bolted central to the vct and the det was bolted hard one way. I ran it how it was set and was lacking alot of top end and didnt keep pulling at all after 5000rpm, so i moved it the same way hard as the original one and still is lacking top end and it feels like its surging when you put your foot on it? Is it too advanced? Could the cas need adjusting? post-140767-14402025659652_thumb.jpg
not sure if related, but when I did my timing kit and removed the VCT solenoid to take the seals off, I over tightened the VCT using a rattle gun (being lazy of course). Some how I jammed the unit and the car was sluggish down below...
Make sure it's sitting in the right position before torquing it up to spec.
Man, I meant the whole vct unit along with cam gear.
I thought it was kind of obvious.
Changing just the actual gear part is a bit pointless, it's the actual vct actuator part of the car gear assembly that needs to be changed.
I changed the whole unit, not just the outside gear, the knocking has stopped, reading up it sounds like timing, a mechanic mate is bringing his scanner over later and will plug it in, to make sure the timings right
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
