Hey all I am a little baffled on what widths/lengths/bends I need to go stainless steel intake. I've recently bought a 90mm throttle body and waiting on a z32 afm and I'm new to piping, also is it better if I relocate for better air flow etc..
Edited by RebelR33
https://www.sau.com.au/forums/topic/458958-intake-piping/
cold air intake and a modest free flowing exhaust and maybe a tune tidy up is about all you can do. Naturally aspirated will only ever breathe atmospheric pressure it doesn't matter how big the pipe is in diameter something has to draw it in or slam it into the motor for it to be effective and you have nothing..
You would get better results from weight reduction and better tires.
good luck
Edited by mr skidz
https://www.sau.com.au/forums/topic/458958-intake-piping/#findComment-7586515
Google:
http://www.sau.com.au/forums/topic/155352-z32-afm-sizing/
you already know size of throttle body
Run 80mm from AFM and step up to TB or run 90mm from TB and step down to AFM..
it faces east to west so you'll need at least 45 or 135(?) degree elbow and straight piece and probably another elbow depending on filter location.
/thread
https://www.sau.com.au/forums/topic/458958-intake-piping/#findComment-7586677
Really I appreciate all of the performance advice, but I'm just asking about my intake pipe.
The honest answer is:
Do not make an inake pipe.
Do not upgrade the throttle body
Do not change the AFM
If you've already done this, do nothing except replace with stock items and sell what you've already bought.
https://www.sau.com.au/forums/topic/458958-intake-piping/#findComment-7586732
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
