A friend of mine years ago ducted his R32 N/A intake into his cabin. Into his cabin. His thinking was when he turned on his A/C, the engine would breath in the cold air, get some performance, he ran without a filter as there was no need for one. Spiders and roaches would be squashed and burned if they'd ever get into the intake. But guess what? After the initial shock he got from insane intake noise from the startup rev, instant regret 30 seconds of driving it hahahaha, and of course, he had to return everything back to the way it was, but with a large hole in his firewall.
There are flexible stainless steel piping available, you could get the correct piping diameter with some coupling for your setup. No need to worry about piping angles. See here:
http://www.summitracing.com/int/parts/wlk-49033/overview/
There is a panel under the stock air filter, if you would take a look at it, there is an outline for turbo piping. You can drill a hole there for either piping your pod, or to let ambient air in. There is a tutorial I think somewhere in the forums.
Do whatever you want to your car, the itch of not doing it when you wanted to do, can turn into a rash. Just don't get hurt or have anybody else hurt. And of course, be prepared for "I told you so, comments." Goodluck buddy.
  • Like 2
haha, would love to see a down shift backfire through the intake. that would wake him up.
i actually wanna see pictures of that.
Sorry mate, there were no photos, this was like in 2001. We didn't even have digital cameras back then, just the film ones. On this island on that year, internet was just starting to get installed, heck, we still use dial up in many homes. I have photos of another buddy of mine somewhere, I just need to find it, where he installed a 6 foot intake to his Toyota Levin. The same piping as the flexible intake link I posted, but at 2.5" diameter. It was way cheaper back then, now it costs twice as much. I'll post it tomorrow as I am logging off from work, such fun times haha.
Reminds me of the guys who used to fit DCOE Webers onto their minis. The intake trumpets used to come through the firewall into the cabin. Then again, intake noise was half the reason people bought Webers, and in those days a Mini was far from quiet anyway, so the Weber conversion was nothing but win.
    • Ok sounds good. Hopefully if I end up changing it to the nismo bushes I don't get that veering issue. I don't think there's a point in lubing up these bushes again. Weird that it it makes just as much noise with all the grease inside it versus without grease prior to removal. Bizarre.
    • Yeah, you don't need camber bushes on stock arms to make a car drive straight unless it's got another problem. F'rigsample, slide the thing into a kerb, bend the front subframe mounts a little....subframe is now twisted, shifted or otherwise in the wrong spot...and you need to do funky stuff with the wheel alignment to get it to drive straight. Maybe a little more caster on one side, or a little more camber. FWIW, I can have my camber off side to side by a half a degree or more, and either way, so more one side, or more on the other, and the car doesn't really want to pull to one side. It will definitely ride road camber differently, and want to track uphill (ie, towards the centreline when on the LHS of a normal crowned piece of road, like it should) or want to roll downhill (which it really shouldn't). But on fairly flat road surfaces, like the middle of a 3 or 4 lane motorway, a half a degree either way doesn't make a lot of difference. I sometimes do quite a few miles with my wheel alignment messed up, because I don't always get a chance to set it right again after a serious dismantling, before I have to drive it to work again. Like, a whole week's worth of daily shuffle.
    • To clarify, I meant nismo bushes, not control arms (don't even think that's a thing for my car). So the suspension specialist said, if I buy those nismo bushes which are perfectly centered it will cause my car to veer in one direction. Whereas he said the current offset bushes that I have were put in on purpose to fix that issue. This will be my third wheel alignment if I put these bushes in lol. My chassis is straight, all my rails are clean.
    • OK, well, in that case, the suspension specialist is either a moron, or you aren't understanding what he was trying to tell you. Nismo arms are not really different than stock arms. Both are fixed geometry. I don't know if the Nismo ones are a little shorter than the stockers (or perhaps even a little longer) or the same length, but....if you swap from stock to Nismo, whatever happens to one side will happen to the other side. It will not cause it to steer left or right. That is unless you have adjustable bushes in your stockers, and they happen to be adjusted to dial out some bent chassis shenanigans. But, if that were the case, you'd just put adjustables in the Nismo arms anyway, because Nismo arms are essentially just expensive stock arms. And doing a wheel alignment is just a weekly thing in my world. I have had the suspension apart so many times this year that I've lost count and just about worn out a torque wrench. I'm out in the shed right now cutting up some alloy section and making bases for my new stringline setup. Got to make new swivel plates next, then I'm good to do toe properly, as well as camber and bump steer.
    • Yeah, nah. Not a thing. The gasket between the top of the plenum and the runners is far more likely to blow out when it gets old, and not really at ~14 psi. These things have been run to double that for 30 years without that being a common thing.
