Looking for EOI at this stage...
A new business adventure is looming and I am looking at a number of options...
Car Build history can be seen under "motorsport builds"....
As can be seen... LOTS spent over a 3 year build...
pm me for further info if required....serious enquiries only please...
post-74499-0-27230400-1439544629_thumb.jpgpost-74499-0-00921400-1439544673_thumb.jpgpost-74499-0-72266700-1439544801_thumb.jpgpost-74499-0-51493900-1439544874_thumb.jpgpost-74499-0-11229100-1439545003_thumb.jpg
Build thread
http://www.sau.com.au/forums/topic/417823-r32-gtr-drc-build/
120K+ + spent... hence my request for EOI's... sell price will depend on what someone wants to pay for it I suppose...but I'm guessing in the current climate it would go for circa 60K...again, its worth as much as someone actually wants to pay for it..
Some brief details below:
Brembo f40/f50 calipers( 355 front rotors/328 rear rotors)
DMS suspension
Haltech
-5 turbo's
N1 crate engine
Twin plate
OS&G gearset
Compomotive
etc etc
PM for further info and details/mobile no... happy to discuss with any potential buyers..
cheers
If only i was one of the 3 to win a share of the 20 mil xD this would have been one of the first things i would buy. Looks great, just went through the build thread! GLWS
  • 2 months later...
Race car is now on my105.
see link below..
http://www.my105.com/ListingDetails/p/1/k/nissan/id/16220
Looking for 45k (also have car trailer and other parts that could go with the car if required)
Additional new build shots can be seen on my basic website below
deleeuwracing.wordpress.com
(you will have type this into your browser)
please pm me if you require any further info/details
cheers
Chris
  • 2 months later...
Guys,
My new business venture is getting closer and closer so I have dropped the price again.... :(
42k ( negotiable)..
I have also added a bit more detail below and some more pics
Recently Completed Build
Build History ( can be viewed under new build photos/video tab) see below
post-74499-0-93245200-1455162578_thumb.jpgpost-74499-0-76478800-1455162605_thumb.jpgpost-74499-0-70991200-1455162629_thumb.jpgpost-74499-0-09369300-1455162644_thumb.jpgpost-74499-0-97243500-1455162666_thumb.jpgpost-74499-0-09247800-1455162691_thumb.jpg
Build Details :
CAMS LOG BOOKED CAR:
Category 3C REGISTERED CAMS TARMAC RALLY CAR
Components:
FULL TARMAC RALLY SPEC ROLL CAGE
RECARO RACE SEATS( Driver/Navigator)
FRESH RB26DETT N1 CRATE MOTOR ** appropriate engine no can be confirmed..(approx 8000klm)
GARRETT 2860-5's (with uprated actuators) **brand new
Haltech ECU **brand new
SPLITFIRE COILS WITH BUILT IN IGNITORS **brand new
NISMO COPY OIL AND POWER STEERING COOLERS **brand new
SARD 660CC INJECTORS
100mm TUBE AND FIN INTERCOOLER **brand new
ARC AIR INTAKE BOX **brand new
KOYO RADIATOR **brand newew
WALBRO 450 E85 FUEL PUMP**brand new
DO LUCK G SENSOR**brand new
EXEDY PUPP TYPE CERAMIC TWIN PLATE CLUTCH AND LIGHTENED FLYWHEEL **brand new
OS GIKEN CLOSE RATIO GEAR KIT
355mm x 32mm front rotors -328mm x 32 rear rotors
BREMBO F40/F50 CALIPERS
PAGID BLUE FRONT AND REAR PADS
50mm DMS SUSPENSION **Just rebuilt
245/40R17 A050M Advan's
COMPOMOTIVE 17 X 18 TH2 +30 RIMs
***Race Car trailer
***2 x Stilo lids
***2 x 3 piece suits
plus some spares etc etc... everything can go as a package
**If your not in WA its definitely worth a flight over
  • Like 1
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
