Happy Laps - Queensland Raceway 19-09-15
Event:
Description:
A chance to get out on track for a fun cruise and have some om nom noms! Bit of spirited driving is allowed but it is still an event on a race track so a few rules need to be followed (see below). Also if you have not done QR before this is your ticket in to Lakeside.
Queensland Raceway
Date:
Saturday the 19th of September.
Time:
7:00 AM Arrival
Cost:
Slight change in the payment form these happy laps onwards:
$35 for members and guests of members riding with a member
$50 for non members
Please note that this is a per person cost, any passengers etc are required to pay as well.
Requirements:
1. QR have a minimum age of 12 for passengers.
2. No overtaking in the first 2 laps.
3. The overtaking car is responsible for completing the overtaking move safely.
4. Overtaking is only permitted on straights, unless clearly waved passed by the car in front.
5. Overtaking move must be completed well before the end of the straight, and the car being overtaken must be given plenty of room.
6. Cars should not be more than 2 abreast at any point on the track.
7. Be aware of cars around you, in front and behind (and beside when being overtaken).
8. Do not assume that the car in front of you knows you are there.
QR RULES
10. There is to be no racing
11. The straights are speed limited to 120km/h
12. Any car that goes off the track will be pulled off
13. There is not to be more than 1 sec of tyre smoke.
14. There are to be no helmets
15. Vehicles must have current registration and number plates are not to be obscured in anyway
Payment Details:
Name: Skylines Australia Queensland Club
Bank: Westpac
BSB: 034 063
ACC: 354012
PAYMENT REFERENCE: Username&HappyLaps
Attendees:
  1. Cadmoon +1
I'll be in. Need to test brembos and Sayc and ALL THE THINGS.
How is this going for numbers? Are JSpec or Evo owners clubs joining this time?
Can I float this to some of the guys over at ozvr4? Could help get the numbers up.
And lets face it, might be a lot of people's only chance to ever see more than 1 legnum in 1 place at any given time :P
I'll be in. Need to test brembos and Sayc and ALL THE THINGS. Including radiator hoses? :P
How is this going for numbers? Are JSpec or Evo owners clubs joining this time? Not a lot. No, they're not interested in joining us after a few non members who drive skylines stirred shit with them.
Can I float this to some of the guys over at ozvr4? Could help get the numbers up. Sure
And lets face it, might be a lot of people's only chance to ever see more than 1 legnum in 1 place at any given time :PBecause they're all broken?
I'll be in. Need to test brembos and Sayc and ALL THE THINGS. Including radiator hoses? :P Yes, actually, all the hoses.
Can I float this to some of the guys over at ozvr4? Could help get the numbers up. Sure Awesome, I'll make sure they all bring spare radiator hoses...
  • Like 1
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
