check this out:
http://www.mkiv.com/tmp/emanage/index.html
a) similar things to a unichip
c) dunno
d) it kills an SAFC is properly tuned but this depends on C....
e) $420? (nengun price) -this price is slightly cheap but you may need to get the extra stuff. My friend bought one... shipped, with software, all additional sensors he paid $1000. This was from perfectrun.
In the end he sold it and bought a Power FC if thats anything to go by :)
Well the AFC only does one thing... control air/fuel. You can do all sorts of stuff with the e-manage like what the Apexi ITC does... or control larger injectors or change to map sensors.... more similar to a PowerFC...
but in the end with all the modules added up its more worthwhile, more proven and theres a lot more tuners for the Power FC.
I also considered this option too but its out the window now...
Originally posted by adam 32
can anyone give me any further details on this?
a)what does it control?
b)what application is it suited to?
c)fitting/tuning ease/cost?
d)how does it compare to other piggy-backs ie S-AFC
e)would you buy one if someone gave you $420? (nengun price)
cheers guys!
adam
a) if you have the E-01 and ignition harness -- EVERYTHING! Fuel maps ; ignition maps ; boost ( across specific rpm ) ; it has a funky glowing screen and takes Flash memory cards so you can store settings for different envionments.It can allow for the running of a MAP sensor instead of the AFM as well.
B) Trust have a 1500HP RB26 running it, there are many people in the US with it on WRXs and Supras etc.
c) The interface is very easy to understand, I think it looks easier than most and with the hand controller you can fine tune on the road.
d) It compares fairly well if you are just getting the basic e-manage box for $415AUS, given you can upgrade it. However in the full house version $910AUS (E-01) + $415 e-manage + $45 ignition harness, it stands up there with PowerFC , it is certainly better value for money.
e) yes I'd buy one if someone gave me $420.
BTW the unichip isn't in the same league as the e-amange or PFC.
Originally posted by INASNT
s-afc aint nothing special, the f con should have way more functions and points of adjustment than the s-afc
The f-con adam found is the pfc f-con, not the f-conV. The pfc is strictly fuel only, using a harness to talk directly to injecors and has no other functions. The ROM is programmed from factory and can only be replaced by ROM options from HKS. I consider is to be far inferior to the s-afc because it lacks the ability to modify ignition timing, something the s-afc can do as a by product of modifing air flow meter values. Ignition timing is where the majority of drivablity gains are made on a RB25DET.
huh?
modifying the the air flow input on the s-afc does nothing to alter any timing!
u need the s-itc for ignition adjustment
Yes, it does affect timing. S-ITC allows for custom timing changes, but thats not to say that the S-AFC doesn't allow for any timing changes.
The factory computer uses the AFM as its main sensor to determine engine load. Measuring the amount of air ingested allows it to switch to an appopiate fuel ignition map. That is, a map that defines fuel and ignition timing. From factory, R33s are programmed to dump a whole load of fuel and knock back timing any time it breathes more air than in stock tune. Its a safeguard against detonation but removes all the fun making power.
Example: lighlty modified 'lines are always running rich and have a flat spot over 5000rpm. Fooling the computer into thinking the engine isn't breathing as much at a certain rpm (using a s-afc to modify afm voltage), relaxes safeguards and allows the computer to switch to a mapping with aggressive timing and less fuel.
Perhaps you should read up on senors in an EFI system and how they contribute engine tuning before you enter ECU related discussions. Sorry, but I dislike misinfomation on forums.
the main point of the s-afc is to lean out the mixtures hence make more power, true the timing might change when reading different afm inputs but that much?, the factory ignition maps r shit house to say the least!
y then can u achive power upgrade with an adjustable fuel pressure regulator, similiar to s-afc when u r just leaning the mixtures out when on boost? that doesnt affect any afm signal.
s-afc mainly gets power increase from running smoother and leaner fuel mixtures
Oh dear, your trying to push the point by using overwhelming ignorance and fallacy based logic. Charming.
I love the fuel pressure regulator argument. Note, I said driveability is gained from timing changes. Power is made from the right afr's but whats the point if timing is continuely retarded and its a slug to drive? Fuel alone isn't going to fix problems inherent in the factory ecu's program.
I'm going to assume your not trying to favourbly compare a pressure reg to a s-afc, because a blanket change in fuel delivery regardless of revs is hardly the most sensible way to go about it. Plus, its the same price as a 2nd hand 1st gen s-afc, which is orders of magnitude more tuneable.
The S-AFC has no direct control over fuel mixtures or delivery, the factory ecu makes its own decisions! Lets not turn this into EFI Systems 101. I'm done.
i dont want to start sumthing either!
i have been at many dyno sessions, including with my car tune and without the s-afc my a/f ratios were all over the place, then with the s-afc tuned it kept a roughly straight 12.1 a/f ratio, by adjusting -/+ %!
so u do have control over your mixtures.
dont get on your high horse and thing u know it all!
:mad:
That really is excellent. I'll add it to the running tally of how many dyno sessions SAU members go to. It counts +5 points towards their overall "I Know How To Tune" rating.
Well! That proves it then. S-AFCs really do change air-fuel ratios. Please, someone bring this man the "Stating the Obvious" award!
bowdown.gif master of tuning and efi systems!!
i know it intercepts the signal to trick ecu so u can run better af's!
either way s-afc offer f*uck all tuneability compared to a standalone ecu!
if i had the $$ at the time i bought the s-afc i would have got an power fc.
Ladies, Ladies, Ladies...
I think what gradenkos getting at is the AFC changes the signals youre AFM puts out, making youre ECU think you are getting more or less air flow.
The Fuel maps the ECU uses are the same, its just fooled into thinking theres more/less air so it puts more/less fuel in. The ECU still controls mixture, youre just tricking it.
Most skylines run rich, leaning the mixture out makes youre ECU think you have less airflow, and you arent working the engine as hard, so as a by product, the timing stays advanced, rather than being reduced at higher revs (it gets rid of the infamous 5000rpm flat spot).
Its people like me who have to make the ecu think theres more air, so i get more fuel who are disadvantaged by this, cause my timing is not as advanced as it could be.
I am the one who needs the ITC!
I know Gradenko has done a lot of research into mods, thats why he ran a 13.8 with the small amount of mods he has done, he knows what things do, and how to apply them. I reckon hes spent more on speeding fines than mods.
Sorry, wasn't my intention to put that image across. Like most of us here, this is just a hobby. Only two things upset me on forums, one is rice boys tarnishing the Skyline name, and the other is misinfomation (sometimes also seen in the form of opinion passed as fact).
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
