Hi guys I have afew questions to ask so hopefully you guys can help me out here.
First of all I want to get a r34 but there isnt any on sale and if there is they are over 30k+
So I want to buy a 25gt for the look.
I want to have a awd instead of rwd however I looked around and found there is too much f**king around and costly to convert rwd to awd
So I was thinking about getting a 25gt 4 since it comes stock with awd However I'm not sure if they come turbo as well I could only find na versions...
I would like to have around 300rwkw after modding
if anyone could list me down the specifics and also how much $$$ per specific mod would cost to turbo from na or upgrading the already turbo 25gtt parts to make around 300rwkw
I would appreciate it.
So my first question is Am i better off getting a 25gt4 and putting a turbo onto it and just upgrading the internals and doing everything at once to make 300rwkw ' How much am i looking at per specific part/mod + labour and tuning ? and is it going to be cheaper to make 300 whp ?
Or
Am i just better to get a 25gtt rwd and just work on it to get around 300rwkw ' How much am i looking at per specific part/mod + labour and tune ?
Or just buy a already modded 25gt that is pulling around 200rwkw for around 20 grand ?
I was thinking about buying a 25gtt or 25gt4 at around 10k then spending 10k on top for more power
which would be cheaper and more cost effective
My spending money will be around 10 grand.
Sorry for all the noob questions
Please dont spam random crap if you have no idea what you're talking about or have nothing to do with the questions asked.
Cheers
https://www.sau.com.au/forums/topic/459003-25-gt-or-25gtt-help-please/
You could answer all of your questions with information both on this forum and on google but okay...
Buy the GTT and live with 2wd or buy a GTR
Turbocharging your NA GT-4 is not really a good idea, you'll need to buy a turbo engine, turbo, manifold, turbo lines, injectors, fuel pump, ECU intercooler and have it tuned before you can even drive it, then you'd probably want to upgrade your brakes to the turbo brakes
Because you asked for costs ill give some estimates
RB25DET NEO Engine $1500 (give or take, healthy low km or rebuild will throw costs out)
Turbo $1000 (buy a turbo then send to hypergear for highflow)
Manifold Stock or custom $50-1000
3" exhaust $500+
Turbo Lines $200
Injectors $600ish
Fuel rail $250ish
Fuel pump $150-250
ECU too many variables from nistune to standalone
Z32 afm + plug if required $100-300
Intercooler $200-500
Tune $600+
Turbo piping as none of the NA stuff will work, budget $400
If you want 300kw from an R34 GTT just buy one, front mount highflow turbo and 3" exhaust with a nistune will net you that.. almost anyway
Turbo $750 (send to hypergear and highflow)
3" exhaust $500+
Injectors $600ish
Tune $600+
  • Like 1
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
