After the best bit of two years sitting around after popping the gearbox, the car finally made it back onto the rollers in Friday night. It didn't feel right so the tune was stopped. This is what came out of my filters.
7B8030C2-FCC0-4CE5-A699-104D2D45403B_zps
7E9CFC5A-1656-4C62-9FBB-9A9D5FBB65D1_zps
The car was parked with 98 in it too.
A fair amount of silty junk was found in the baskets of the injectors also.
what's that gunk?
You running rubber lines Paul? That looks pretty bad...
Some are.
After seeing this, I'll be going back through the fuel system with a fine tooth comb.
I've never had an issue like this before and the car has been using E85 since 2010.
I have seen rubbery crap blocking the injector baskets a few times, I can only guess it's the inside of the rubber hose breaking down.
It's different to the molasses sticky mess that sometimes builds on the injector tip, after cleaning a few Audi RS4 plenums it looks like the same gunk they build up in the runners and around the valves, just a symptom of long valve overlap or high exhaust manifold pressure I suspect. Interestingly it's only one injector that gunks up in some cases, so I can't see the fuel being the direct cause.
Got fresh engine, (i.e so no carbon anywhere) running on E85 for awhile since runin (10,000kms?)
Put a tank or two of 98 in, to satisfy demons in case of evil e85 doing e85y things.
Put E85 back in after sufficient demon-cleansing time
ton of shit in fuel filter and car running lean under boost, thanks, Haltech engine protection!
Knowing exactly 0 about 98/E85's cleansing properties, clearly the combination of the two either causes gunk, or flushes gunk in/out from somewhere, my filter was fine and my AFR's were fine until I put 98 through the car. Funny enough, was fine on 98 also, but obviously less fuel there as less is needed so a partial filter blockage may have had no effect.
Very interesting! Which Haltech has this function for lean out?
I have a PS2000 but many of them have the feature, basically you can input criteria or safe operating ranges and if you exceed them you can have the engine respond. I.e cut all fuel, set a rev limit of 3k, pull timing, or any combination of them.
In my case I have a wideband so it was a "Is my AFR leaner than 12.5 with boost higher than 1psi for longer than 1 second". Combined with auto logging if I'm above 70% throttle, it's pretty easy to determine through logs what happened and why. Can set it to trigger off oil pressure, fuel pressure, various temperatures, etc.
Considering I was driving it just fine on that filter on E85 on many many dyno pulls, Deca day, Drag passes etc and this mysteriously started happening after I ran E85 after a tank or two of 98, AND had a clogged filter (replaced filter working fine now) then I can only hazard a guess that the swapping of fuels caused something to dislodge :P
My 2 cents, I've been running E85 for about 2 years now and only recently gone over to a flex setup... I've also alway have used cheapy Ryco filters and bing then each time I do an oil change. The only thing I can think is that I've replaced all my old OEM Nissan fuel lines with Gates Barricade (except the hose from the LHS side of the tank that cross over into the lid then to the "jet pump".
Not long ago, I decided to pull out my injectors to have a look, they still seem quite happy.
Are those filter elements from the fully hectic alloy 10um filters with cleanable /replaceable elements?
If you cut up a std Nissan steel jobbie one do you expect to see the same thing?
I believe they are stainless mesh cleanable type. But good luck cleaning my old one above.
That's a good plan as they are cheap and easy to buy
    • Dissimilar metal corrosion. Aluminium is less noble than steel/iron, and will corrode preferentially when in contact with it and a conductive solution (ie, wet road salt). Tends to suggest that those brackets should be made in steel for a shitty climate like the UK.
    • Here is picture of the rear brackets again seeming to have eating itself or corrode or whatever. Can’t describe it , hope someone could explain this
    • No i am in the uk so maybe road salt etc but checked rear and same story where handbrake cable seems to have eaten part of the bracket. Have emailed alpha omega waiting for reply
    • I've not looked at a GTR without the booster there. Is the hole and mount on the firewall not just the same as GTSt? I would have expected it to be. Nissan don't change panel stampings if they don't have to, and you'd think they'd just order/design the booster to mount to the same place.
    • They have all sorts of "failure" modes. When they are brand new, the can either be very very tight, or reasonably mobile. If they are reasonably mobile, you'll probably have a good start. If they are very tight, then they can catch/grab at every little motion, and they mark the ball or the outer race, tearing off whatever teflon lining is in the outer race, then they can rapidly degenerate from there. If they get wet, they can just rust. They are just steel and will turn red pretty quickly. Water can get in behind them and sit and cause them to become crunchy and then proceed to tear themselves up, as above. Same with grit and dirt. Manufacturers and OEMs of the arms that use them will tell you that because they are teflon lined (well, the good ones, anyway), you shouldn't grease them. If you do grease them, then the grease will catch any passing grit and dirt and hold it in place where it can cause damage. Race teams that have them will lubricate them thoroughly. They will also inspect them every 5 minutes and replace them every 10 minutes, if need be. Some manufacturers of arms will provide dust boots. These can help, but they are seldom perfect, and sometime just make the situation worse, being a place where crap can collect. I have made nappies for some of mine with PVC sheet and race tape, to try to minimise the access of crap. When they wear, you can get a tiny tiny amount of movement between the ball and the outer race. This will make clicking noises. It will also make the arm have "slop" in that the tiny amount of movement available at the inner end of an arm can cause a lot of movement out at the outer end. 0.05mm at 5mm from the pivot becomes 4mm 400mm away from the pivot. If they are too tight and binding, they impede the proper motion of the suspension arm and put loads into it and the rest of the suspension that are not supposed to be there, and can cause failure. Think broken welds, broken threaded sections on the adjustable parts, mounts ripped off the chassis, etc. All of these are possible, which is the main reason why they are essentially illegal on the road in Australia.
