Hi everyone, Greetings from Darwin, that's my first post here - so... I bought my first Skyline last week(r33 gts-t) and it started blowing blue smoke couple days ago every time when I've been driving steady for a while and then put my foot down to 4000-5000rpms on 1st and 2nd gear.
Also all the oil breather hoses were either broken or blocked and oil was leaking everywhere and got oil pressure warning light all the time, anyway replaced these hoses and serviced the engine(no i didn't overfilled with engine oil) and now it's blowing blue smoke. Pulled the turbo/intercooler pipes off and there is fair a bit of oil there but turbo is all good, no odd shaft play. Could it be the oil rings ? Cheers
https://www.sau.com.au/forums/topic/459023-r33-rb25det-blowing-blue-smoke/
Is that with the blue ring coming out of rocker cover ? Pulled that hose off and tried to blow air through the valve, it works only one way, can suck air out from engine but can't blow it back.
PCV looks okay, looks fairly new
You can test if you want, its just a check valve so you should be able to blow through it in one direction and not the other
Catch cans arent really necessary on stock or near stock cars, im not sure what is done to yours
If that's how to test it then yes it works.
I'm thinking that because of that one blocked breather hose on top of rocker cover was completely crunched that no air could get through, engine had too high oil pressure all the time and old owner just kept driving it, so it blew the turbo seals coz it seems to have bit too much oil in intake?
Yeah it's near stock:
3" cat back exhaust
Front mount intercooler
Pod filter
stock turbo and turbo controller at the moment
Does the oil level drop now that youve fixed it? Im wondering if its just burning off oil that was in the wrong spot because it wasnt breathing properly. May be turbo but its good to rule out cheaper/easier things first
Check your inter-cooler piping for oil, especially at the lowest point.
We had exactly the same issue on a R32 GTR after a track day, found the blowby oil got into the intake piping when we pulled the intercooler off, every time we got the revs up hard and onto boost it was smoking.
Cleaned out the oil, problem went away, then fitted a catch can to stop it happening again, it never returned.
Thanks guys, will clean the intercooler and piping out soon as i got time + replace spark plugs after it's not burning oil anymore. Definitely will fit a catch can, redirecting oil to intake seem like a bad idea.
Alright, now i have a boost leak so i pulled some hoses/pipes off to see what's going on. Found that someone has blocked off the bov with a piece of tinnie, what's the go with that ? See picture below :
Built a pressure tester to find the boost leaks, got rid of all the leaks but still feels like boost leak and lack of power on higher revs. So i pulled off the turbo, intercooler, pipes/hoses. Found some pieces of metal inside the intercooler and engine oil has turned black(just serviced about 600km's ago). Turbo has a slight shaft play inside-out but not side to side, cold side wheel looks a bit rough. Drained all the engine oil, luckily didn't found any metal pieces from oil. Apparently turbo was just replaced before i bought the car so might it be that f**kers blew the old turbo up and didn't clean the intercooler??? Still doesn't explain why I get 15psi of boost and that sucking noise like a boost leak+ stalling when turbo is supposed to kick in. Might need to start looking for a new turbo... :rant:
Yeah mate, cleaned the intercooler and piping with degreaser and hosed all the dirt out. I didn't put anything back together because my concern now is what kind of damage all that has done already. Been just browsing different topics here for hours already, reading about Kinugawa turbos at the moment, probably takes me another couple days to finish that thread lol.
Also i just remembered now that when i was doing the boost leak test, @10psi oil dipstick popped out and released all the pressure which seems bit odd on such low pressure.
Forgot to take a picture but here's a picture from Google how i did the pressure test:
Still trying to figure out whats wrong with it, made a short video of that whistle sound.
https://www.youtube.com/watch?v=wVQwkeTv5j0
Wanna get my car running properly again, might go for a new turbo if can't find the problem soon.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
