I used aerfoflow hose, can't remember what series. And I did all my water/oil/fuel lines at the same time so I can't really remember.
If you were just to do the soft lines coming out of the fuel tank hat, and in the engine bay I don't think it would be more than $100
Little value in going E85 with std RB25 turbo. E85 is great at allowing you to wind boost into an engine and you are capped at 12-14 psi
Given the expense of going to E85 a HKS 2530 on 98 will be you better results
not entirely correct, you're still able to run loads of timing around the middle of the rpm range without any knock and a few more degrees up top
Meh... It made my car a smidgen laggier but did allow way more ignition. But takes a better calibrated bump than mine to pick that up in back to back driving through the mid range.
But only really made more power as the engine was no longer boost and ignition sensitive so could wind both in.
With a std turbo it will be bye bye exhaust wheel. Though with lower exhaust temp maybe you can run 15-16psi...who knows
No problems with the M35 ceramic turbine, I bumped mine up to 19-20psi on ethanol, for 5 months in between Garrett GTX's. Perhaps the ceramic is glued better on the Stagea? They run 14psi stock.
It was a low K turbo so I suspect it's old age or heat cycles that kills ceramic turbos more than boost or shaft speed. Anyway it's not hard to shove a small highflow core inside it.
In addition if I were to get a upgraded turbo I'd need injectors and a nistune anyway so the only extra expense I'm seeing at this stage is fuel lines, rb25 highflows are quite cheap second-hand and plenty of them around however most say they are too laggy for an rb20
There's your answer. RB20/25/26 turbos were spec'd to run at 7-10 psi. So they would have been running at a certain shaft speed to achieve that. Try to make 14 psi and they have to go a lot faster. The M35, if standard is 14 psi, will be doing the same sort of sensible speed as the older ones at their standard boost. Wind it up to 19 psi and now you're probably approaching the same sort of speeds that limited the older turbos - just at a higher boost.
It's kind of like how you could get away with running a 25 turbo on a 20 at higher boost levels with less risk of it dying - because it wasn't having to spin quite so fast to make the boost on the smaller engine.
Well my car is about ready to be all put back together and get back on the road. Will be interesting to see how this weekends inspection of tank, lines and filters goes since it has been laying around with E85 in it for 12 months.
I mention that as my car has nothing done to it all to make it E85 compatible. Just 1000cc injectors and in tank pump with Nismo reg. Ran fine like that for 2 years but was driven every 2nd or so day with a tank a week
I've heard stories of the e85 gradually breaking down the stock rubber hoses leading to gunky buildup in the injectors/fuel filter, and as in your case people have left them untouched and it's been fine, honestly if it's a cheap and simple thing to do I don't see a reason not to
Here's an idea, just run whatever boost you run on 98RON safely, then on E85 run the same amount - however just pump in loads and loads of timing till the motor/turbo combination stops making power and back a couple if degrees.
At the end of the day, it's going to still make more power than 98RON, not a totally pointless exercise.
For reference, I tuned my mate's S15 and it made 197kW on 98RON.. when we moved it over to E85 it made 215kW - however it made heaps more mid range power as I was able to pump in heaps of timing into the notorious SR20 timing hole where max torque is achieved.
LOL...Ive actually been following my own advice and I'm up to P14 of the RB20 turbo thread and god dam, kudos have the that HKS on special for 3.14K...http://www.kudosmotorsports.com/catalog/hks-turbocharger-kit-hks-gtrs-11004an008-nissan-skyline-r32-gtst-gts4-r33-gts25t-r34-25gtt-p-1048.html
    • Dredgggggeeee time; I have recently finally started driving the car. It sat for so long that the fuel tank gave birth to rust sludge and blocked my lift pump sock and one of my walbro 460's and left grime, rust chunks and muck all through the surge tank and system. I decided to commit and pull the trigger on an oem r32 gtr fuel tank and Frenchys twin 460 / sender / surge tank hanger combo and all new larger lines and fittings etc, also boost doc heater hose kit / new heater core and a heap of other bits and shits like wideband sensor installed in the dump and Syltech iacv + lines and all wired and added to current tune. now having lightly driven it a couple times without issue, I can happily report on the hta3076 in its current tune. still no boost control switched on, 20psi gate springs, car makes 22psi at 3200rpm in 6th gear with 30-50% TPS from cruise at 100kmh. Going by the old graph, this means it should be making 300-325whp at the same numbers above. Very very responsive setup under true road driving loads. all that's left for the build is body loom + PDM, finish the remote aircon setup, install carbon fibre parts and go for full tune and 30psi. the 315 rear tyres are now performing like they're 195's, wheel spin in any gear at almost any rpm, whereas my previous setup hooked up in 3rd no issue, albeit Nt01's back then / RB25 5spd vs (new) old date r888r's Z34 6spd now, + obviously all the support upgrades I listed in the quoted post above. car sits at 1-3psi on cruise at 100kmh, expectations totally exceeded and I'm beyond stoked with all this so far. IMG_4848.mov
    • I've also been eyeing their rear axles for my car. I purchased seat mounts from them about 7 years ago and they were hot garbage so I've been a little wary about purchasing them. With that being said, please buy them and get back to us haha.
    • Can a moderator please move this into the right category.. I've accidently put this into racing build thread 🤦🏽‍♂️
    • Being a manual, we very quickly ordered new R34 gearbox (From Nissan) and remaining parts from Kudos motorsports. Would highly recommend the team there. Ultra helpful and quick to share advice and upgrades. We are in the middle of taking the Auto out (Genuine 94,000/kms) and putting the Manual in this weekend. Part 2 of the build will include likely a Plazaman Intercooler and Plenium, Hks Exhaust with Tomei Dump (ordered).
