I live on the gold coast and have only seen an one R34 the 5 years I've been living here. I've also been searching to buy an R34 within this region for a reasonable price but there are rarely any decent condition ones for sale. All the immaculate ones I see are in Melbourne.
Edited by whiskybrah
https://www.sau.com.au/forums/topic/459052-how-rare-are-r33sr34s-in-queensland/
33 are common as mud in Brisbane, 34 are not as common but by no means rare. They're 13-20 year old cars now and most have been bought by young kids that didn't maintain them and thus they become flogged out. It's very hard to find a good condition 33 and a bit easier but still hard to find a nice 34. The only advice I can give is to keep looking.
Yeah, I've been looking for the past 8 or so months now, of course you get a great one popping up every now and again but I guess its just me becoming impatient, as the last offer I tried to follow up sold within the first 10 minutes of being put on carsales, lol.
If you're going to Sydney to look at a car I'd take someone who knows what to look for with you. The pressure will be on to buy it there and then so you have a way home but you should be prepared to walk away and catch a plane home again.
  • Like 1
I did the interstate trip when looking for an R33, car was nothing like the pics and was a dissapointment but live and learn i guess, be prepared for alot of bullshit artists and test drive some cars with good power to compare ...
  • Like 1
Cant you go to an import dealer in Brisbane? Look at some skylines fresh from Japan. Im the first Aus owner of my R33, bought it stock as a rock and it was clean as bar some damage to the dash (think the previous owner had something mounted there)
It cost me a little more then going for a private sale but i did end up with Warranty and probably a much better looked after car
Hey mate, I was searching for a clean 34 GTT on the Goldy and surrounding areas for a few months and, ended up travelling down to VIC to pick mine up.
As for spotting wise, they're out there, I see a handful every couple of weeks but 33's are more common that's for sure.
If you're looking at cars in Sydney or Melbourne, hit up one of the guys from SAU NSW or VIC. They will be able to point you in the direction of somewhere reputable that can do mechanical checks etc and may even know of the car in question. Book a return flight on your first trip down and try and see a couple of cars. That way, the pressure to purchase then and there isn't on. Head back down to drive it up after placing a deposit. Mate sold his BNR34 to a guy in Sydney and that's what they did.
Hi have an R33 available, still in good nick, I am just in northern suburbs of Brisbane, You are welcome to come and check it out, take a test drive also, no Obligation.
Call Scott 0410091018 to arrange a time.
    • I removed the head expecting to find broken and bent valves, but instead found number 1 at TDC and cylinder 2 at the top of its cylinder stroke as well, thought that was weird and proceeded to push cylinder 2 back down until it either bottomed out on its other piston half or the conrod either way we found the issue kind of,  now to remove the engine and see how the block looks, hopefully its just the top off a piston.
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
    • FYP. Sadly. Even bolt cutters wouldn't take 2 sec. But in the days of 18v angle grinders, nothing is safe.
    • One piece driveshaft I would recommend a dual CV setup otherwise stick to OEM. I have heard most one piece driveshafts cause excess vibration otherwise. The transmission grind I'm quite familiar with. You can try shockproof gear oil, otherwise you need a new transmission. The shifter is extremely simple on these cars. If you want pull apart the assembly and replace the plastic bushing but I doubt that fixes anything. The tail light issue is very common, unfortunately new tail lights are long discontinued. The trunk antenna going up always is because your radio doesn't have a true power antenna control, just remote amp power signal. There is a blank switch plate that you can pop out and install a switch for this or alternatively source a head unit that has proper antenna control. Throttle body sticking you have to disambiguate by disconnecting the cable and seeing if the linkages are the problem or something else. There is a procedure to adjust them, refreshing them is also somewhat involved if that's the issue. I have dealt with many of these issues. Old cars really are fractals of problems. The more you fix the more you discover there is to fix.
