Nice looking kit, were the bolts 12mm or 14 though?
Different kits/cars require different bolts - mine uses 14mm bolts
What size rims do you have, and how much clearance between the caliper & rim barrel? The AO website says minimum 17", but I'd be surprised if they would fit - more likely 18" needed?
I run 18's, I use both stock R34 GTR rims and Concave Concept CC03R in 18x9. I have seen the setup with 17's but you would require a race-style 17's which provide maximum clearance.
Out of interest... Can you pull the ABS fuse and do a session and offer feedback?
If I remember next time I'm at the track I will see what I can do :)
Your original question was, will they fit behind a 17. If the website says it does then why would you be "surprised it fits"
Would have taken you less time to search what the standard Evo wheels are
Don't get cranky when it's easy to find the correct answer, especially since ITS ALREADY ON THE WEBSITE!
Thanks - just changed from 18's to 17's on the track car to get the tyre sizes we wanted, but would love to put the brembos on.
Edited by GeeDog
Perhaps you should read my original question again - doesn't mention "behind" anywhere. I asked about the clearance between caliper and barrel - ie diameter. The standard Evo wheels mean nothing - this kit uses calipers from early models and rotors from newer model, with a third party bracket. Thanks for the excellent info provided though, EVEN IF IT IS ALREADY ON THE INTERNET!!! Don't you be asking anyone for info again will you (particularly just after they've offered to provide it)?
What 17's are you running? Here is a pic with some 17x9 Enkei's fitted over the kit - http://alphaomegaracing.com/image/data/productimages/evo350brembo/wing.jpg
I'm sure if they are a known brand rim Alpha Omega would probably be able to advise if they will fit over the kit, you may need to be cautious of wheel weights though.
Forgive my ignorance, but why weight? Too much for the hat?
the little lead weights that are sometimes stuck on the inside of rims to balance them ;)
Correct, I'm referring to the lead weights used for balancing wheels when you get tires fitted :)
We've got 17" Enkei's - RP01's - so might be a goer.
I put an Akebono BBS on a 350GT a couple of years ago, didn't think to look where the weights were. They came off the first time the wheel rotated. When I got them re-balanced I got the weights put out of the way of the caliper. Interestigly they were also 350mm rotors, but even the stock 350GT rims didn't fit over the front calipers - missed by about 1-2 mm. I used a set of 350Z stock rims and they had plenty of clearance.
Prank - put the stick away - I'm done with it. Just get a bit sick of reading meaningless replies, and was in a bad mood yesterday after dealing with retards all day. Getting too old and grumpy for this shit.
  • Like 1
  • 4 years later...
@timmy_89
I'm about to put this kit and the rear WTAC kit on my car.
Looking at going the attkd 2 piece rotors after reading what you have posted here.
I wanted to ask where and how much the brake lines were to get made? Or is it easier to just pay the $270 for front and rear lines from Alpha omega?
On 28/07/2020 at 12:16 PM, Darmanin10 said:
@timmy_89
Have you asked AOR for a package deal or seen if they are doing any group buys? I saved a heap by emailing them and found out a group buy was underway
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
