Forge Performance do them at a good price.
Adelaide hills
Another +1 for forge performance
Thanks guys. I will give them a call on Monday.
If the price is good I will see if I can post to them. :)
Will let you know
Hi guys,
Tried forge performance and they would not give me a solid figure just said 'couple of hundred' they said they were also busy so may not be able to do it for a couple of weeks and so on.
Anyone know someone else?
Cheers
Hit up Mark (GOD12A on here) he did mine for me, was quick and good price.
i know josh has been flat out as of late but charged me 150 for mine as a change over he sent one out and i sent him mine back
Thanks for the recommendations!
I ended up finding someone in Botany NSW who did the job for me.
A.E.P Sheetmetal. Cost is roughly $150. Guys name is Neil and he was very nice and helpful.
(02) 96951455
DSC 0435
Modified Twin Turbo Pipe 14
Modified Twin Turbo Pipe 3
Modified Twin Turbo Pipe 2
    • bump. Anyone had this done? either 49 or 50mm? Been pondering what to do while mines in storage. Been thinking of DBW but if I do that, then might as well do this too. Want to retain 6 throttles. I have a fully build head(CNC, OS valves, 286/278 cams, etc etc still running squish), and a Greddy old school intake with port matching. Head bench flowed 300cfm. Wondering whether bigger throttles will give me any gains. Makes 563kw.
    • If anyone has any suggestions for a 300-350mm long (or thereabouts) muffler that is 3inch in and out I'm listening
    • It's the same with many brands that find their way into promotion via Youtube channel sponsorships. Those stainless guys, e-mail cut shippit, various other service and product companies.... they try to make it so that the only name that comes to mind when you think of doing those things is them, and then you just go get their stuff because your favourite channels are using it, so it must be good AND good value. Notwithstanding that the YT'ers don't pay anything for it. But a lot of people are not that sophisticated.
    • Yeh vibrant looks a bit overpriced, but thats the US market in general, they pay $50k for a gtst...
    • It's surprising you say this because talking to someone who headed Toyota's CARB certification efforts and was now working for Mercedes doing similar things he said he never had a case where he found that it was necessary to reduce ignition timing for that reason. Knock limits yes, but never because of in-cylinder emissions profile. I'm guessing between EGR and the number of TWCs modern cars stack in series it's not really a problem. I really doubt the NEO is that big a difference. You get what, EV6 injectors, coil on plug, a cold start valve that works off coolant temp instead of basically fixed time constant valve, and... I really can't think of anything else. Not like Toyota where they shipped first gen GDI in the 2JZ-FSE.  Something I didn't realize is that Japan didn't revise their emissions standards for light duty passenger cars between 1978 and 2000. I'm guessing there's a bit of phase-in, but that explains why 2002 killed a bunch of JDM sports cars off all at once. FD3S, A80, S15, Z32, R34, Z15A GTO all died off for that reason. And explains how all these cars got away with no EGR or much of anything other than a TWC and charcoal canister for the longest time.
