i'm looking to do as much DIY as possible. I've done a dashboard reskin on a ford ranger, but never on a gtr. I'm looking for pre-cutout / vacuum pieces so i can rip off the old, and glue on the new myself.
Same with doors and other interior pieces too.
No i havnt, read lots about it and been thru build threads where they did it themselves, keen to do it but not at the top of my priorities right now.
might have to google it and have a read over the weekend
Received the gaiters boots. Actually, not bad at all. I'll be buying their dashboard cover. I just have to figure out what the strongest adhesive is I can use on the dashboard and leather material.
Those look good, can you provide some more information on where you got those? a link maybe?
Cheers
final result came up well.
i just ordered a new nissan gear shift boot from rhdjapan. they didnt have an original handbrake cover tho :(
i love that grex knob Velict. was on the hunt for one. ended up purchasing a nismo GT500 titanium lol
got pics of your knob mate? your GT500 that is!
Got a set of the Superior Auto Creative gear and brake boot in the CF-look style and a nismo duracon shifter.
Both took a little massaging and the gear boot needed to be folded to fit my shorter shifter, brake boot was easy.
dat oem nissan box! usual quality from nismo
21621535565_f84727570c_b.jpg20150922_184449 by Oliver K, on Flickr
and fitted up
21630399371_2c4fee5a40_b.jpg20150922_190138 by Oliver K, on Flickr
Edited by WantGTR
  • Like 1
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
