Interior Upgrade
Velict
 Share
i'm looking to do as much DIY as possible. I've done a dashboard reskin on a ford ranger, but never on a gtr. I'm looking for pre-cutout / vacuum pieces so i can rip off the old, and glue on the new myself.
Same with doors and other interior pieces too.
Received the gaiters boots. Actually, not bad at all. I'll be buying their dashboard cover. I just have to figure out what the strongest adhesive is I can use on the dashboard and leather material.
No i havnt, read lots about it and been thru build threads where they did it themselves, keen to do it but not at the top of my priorities right now.
might have to google it and have a read over the weekend
Those look good, can you provide some more information on where you got those? a link maybe?
Cheers
final result came up well.
i just ordered a new nissan gear shift boot from rhdjapan. they didnt have an original handbrake cover tho :(
i love that grex knob Velict. was on the hunt for one. ended up purchasing a nismo GT500 titanium lol
got pics of your knob mate? your GT500 that is!
Got a set of the Superior Auto Creative gear and brake boot in the CF-look style and a nismo duracon shifter.
Both took a little massaging and the gear boot needed to be folded to fit my shorter shifter, brake boot was easy.
 Share
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
    • Is the RB26 actually that far off the mark? Honestly from where I'm sitting a VR38DETT is not actually that much more advanced than the RB26. Yes, there is a scavenge pump on the VR38, it's smarter in a number of ways but it's not actually jumping out to me as alien technology. Something like a B58 or V35A-FTS on the other hand has so many surprising little design features that add up to be something that just isn't comparable.
    • https://www.carsales.com.au/cars/details/2021-nissan-skyline-400r-auto-rv37/SSE-AD-17857548/ Well there you go
    • Chris won't reply. He doesn't visit the forum much anymore. You can try these guys https://www.facebook.com/autotainment/ They did mine many years ago
